Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 23 9:03 pm)
Just had a sound bit of advice from the "hacker"- ask me how he did it??? in any case seems if we have the panys, shirt, socks, shoes and head the games won as we can use a standard body. That makes it easier for all. Wow Thanks again people now we only need the above and not a whole model!!! Shane Hacher- how did you do that
Looks like this projects in good hands.Wow from hair pulling worry to amazied in a few min's. I had to drop out as it was 2:am here in Tanzania. Will be in the bush till Sat, so if no feed back do not discourage, Meggis watching over the shop.Now if we can ambush a morph wizard some where for the face. We Win!!! ThanksAgain Shane
If our good friend has a better idea how to prevent the spread of this pest we will be glade to implement it, and know quite a few others who will do the same. Condoms may not be elegant but they do work! The condoms are donated, our problem is to get people to USE THEM. If it seems we are using every trick in the advertising manual to do that- well- we are. Is that so bad, if it helps a few thousand people avoid this thing????? Shane
I knew you guys were on the up and up. Never fear I'm still working on the texture. I am waiting for the Overalls and then I can make that too if needed. Perhaps we should post at the head of the forum since this thread is so many pages back. This way we can respond quicker! Take care out there, PAN~
