Sun, Feb 9, 6:24 PM CST
Forum Moderators: Staff
Subject: Import Question
jcrous ( ) posted Sun, 13 January 2008 at 3:51 AM · edited Tue, 04 February 2025 at 4:34 PM
I am relative new in Poser 7 (Total entry)
I have imported a model in  an .obj format that display absolutely beatiful and fully textured.
I had to scale the model til it is correct.
The model consists of about 10 parts and 2 textures and 2 bump files.
Currently the model and files are in a temp folder.
How do I save the model as a prop so that it will lie in the various folders of Poser.
I know how to draw in the pp2 file and thumbnail, but I can not figure this out.
There are several morphs build in so that it can be moevd by dials afterwards.
Regards
Johan
jcrous ( ) posted Sun, 13 January 2008 at 7:12 AM
OK,
I have managed to do what I intended.
Being too impatient to wait for an answer a crash course in pp2 file editing and 50 tutorials that say nothing, I managed to copy the files where it is suppose to be and edit the pp2 file until it worked.
I am serious when I say that there are so many tutorials that actually do not provide any answers, but just info that several others already gave.
Anyway, by struggling you learn the hard way but then you will forever remember.
Regards
Johan
markschum ( ) posted Sun, 13 January 2008 at 11:56 AM
If you import an obj , scale and texture it . You save it to the props library by seleecting the props tab in the library list on the right , and use the + button on the bottom . Follw the prompts to select a subset an give it a meaningful name . Poser will generate the library thumbnail for you .
