Fri, Jan 3, 6:12 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2024 Dec 29 10:47 pm)
Carrara Free Stuff here.
Subject: Changing the axis
mhscspo ( ) posted Wed, 16 January 2008 at 11:23 PM · edited Fri, 03 January 2025 at 5:53 PM
How do you make "Y" the up axis in Carrara 6 Pro?
Hoofdcommissaris ( ) posted Thu, 17 January 2008 at 2:44 AM
Rotating the whole scene including the camera. But why should you want that? Is it for exporting to other programs? Most of the time you can change that when exporting. Good luck!
mhscspo ( ) posted Thu, 17 January 2008 at 2:57 AM
Quote - Rotating the whole scene including the camera. But why should you want that? Is it for exporting to other programs? Most of the time you can change that when exporting. Good luck!
Actually, for import purposes and to keep the coordinants from Poser
cryptojoe ( ) posted Thu, 17 January 2008 at 4:18 AM
Poser is kind of stiff about their axis orientation, some applications will give you a Y-Up option for OBJ exports.
I would suggest rotating the object after you have loaded it into Carrara, instead of rotating the camera, especially if you have multiple objects whose orientation is correct in Carrara.
Yank My Doodle, It's a Dandy!
mhscspo ( ) posted Thu, 17 January 2008 at 10:00 AM
Quote - Poser is kind of stiff about their axis orientation, some applications will give you a Y-Up option for OBJ exports.
Thank You
