Mon, Feb 3, 9:53 PM CST
Subject: creature creator question.
meltz ( ) posted Fri, 18 January 2008 at 5:39 PM · edited Mon, 03 February 2025 at 9:51 PM
Does anyone know anything about creature creator?  I know its easy to make a creature, then i import it into poser. But what i want to know is how can i make this creatur poseabule like my other modles?
MegaJax ( ) posted Fri, 18 January 2008 at 7:00 PM
You would need to create Groups for each of the body parts and then rig it with bones. Not something that will be quick and easy as once you have Grouped and Rigged your creature you then have to adjust all the rotation, falloff and bend settings for each of the bones.
meltz ( ) posted Fri, 18 January 2008 at 9:22 PM
lol ok way to much for me to even try or understand lol
MegaJax ( ) posted Fri, 18 January 2008 at 10:00 PM · edited Fri, 18 January 2008 at 10:01 PM
OK option 2 would be to try and use a skeliton from one of the figures that is already rigged, for this all you would need is say a V3, M3, G2 or alike figure that has the bones you need for your creature.
Note: This Might Not Work but is Worth A Try**
Step 1, load your creature into Poser
Step 2. click on the Setup Room tab and click OK on the warning dialog box.
Step 3. find the doner figure in the librery and load it.
Step 4. Tweek the bones to better fit your figure, you can delete or add any extra bones as or if needed.
Step 5. Open the Grouping Tool
Step 6. Click the Auto Group button
Step 7. Close the Grouping Tool and Exit the Setup Room
Step 8. The Moment of Truth, If all goes well you should now be able to pose your creature.
Step 9. Save your working Creature to your folder in the Figures Librery.
As I say this way might or mightnot work, good luck.
Steve
meltz ( ) posted Sat, 19 January 2008 at 10:04 AM
awsome ill give that a shot as soona s i get a chance =) thanks man
