Are you using Rhino3d? If so, try the blend command. Its under the surface tools. You might have to trim off a little of both surfaces to get the blend to work right. If this doesn't work try asking in the Rhino forum. Good luck
____________________________________________________
"The true sign of intelligence is not knowledge but imagination".
Albert Einstein
