Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 17 8:56 pm)
The Battlebot ND from DAZ does the exact thing in Poser 7, but it's perfect in Poser 6! When the armor sheath is conformed, the top half simply disappears! It's the most mysteious thing I ever seen in Poser. If anyone has a fix, I'd appreciate it,too!
I cannot save the world. Only my little piece of it. If we all act
together, we can save the world.--Nelson Mandela
An inconsistent hobgoblin is
the fool of little minds
Taking "Just do it" to a whole new level!
They should be visible WHETHER they are conformed or NOT. I think they are connected, if not the same problem from different sides of the coin.
I don't know if it will help them show but did you try changing the display style. Cartoon with line might help. I know it isn't a fix, but you might be able to see it to work with it. Of course if you can't see it when you render, that won't help you.
No, it wasn't the transparency settings--that's the first thing that got checked. It does seem to have been fixed, though. If you conform it, then delete the character you conformed it to from the scene, save the wings (or whatever) to the figure library then load it again, it shows up just fine. So you may want to try that, Joelglaine.
It wasn't the mode either---it was some issue with Poser 7 and the V4 Developer's kit.
But a fix was discovered, so it's not a problem on this end anymore. :)
I'm having a bit of a problem with a pair of wings (cr2) that are invisible until you conform them to the character. This only happens in Poser 7, they load perfectly fine in Poser 6. Does anyone know what the problem is or how to fix it?
Thank you in advance!!
Laura
