Mon, Feb 3, 11:04 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: No ground shadow with HDRI?
pauljs75 ( ) posted Mon, 04 February 2008 at 5:47 PM · edited Mon, 03 February 2025 at 11:02 AM
Same pic with HDRI for lighting. One with a ground plane and one without.
Noticing that in the HDRI only image, there's no shadow on the ground. Is there a particular trick to making one appear in HDRI-background type scenes?
Only thing I could think of is to make some kind of invisible shader that picks up the shadow, and apply that to a ground plane. Does that sound right? Is there such an invisible shader included anywhere, or is that something I'm going to have to make up on the fly?
Barbequed Pixels?
GKDantas ( ) posted Mon, 04 February 2008 at 7:53 PM
What you want is the shadow catcher shader but it doesnt work with GI...you need DCG plugin to do work with GI:
http://www.digitalcarversguild.com/plugin.php?ProductId=13
Follow me at euQfiz Digital
GKDantas ( ) posted Mon, 04 February 2008 at 7:59 PM
In the top shader assing a Lightning Model > Shadow Catcher, but this dont work with GI like I said you will need the DCG plugin to work with Sky Light or Indirect Light
ikercito ( ) posted Tue, 05 February 2008 at 7:59 AM
I can't believe you still need to buy a shader for that. That bug should have been fixed long time ago....! :(
ShawnDriscoll ( ) posted Wed, 06 February 2008 at 2:30 AM · edited Wed, 06 February 2008 at 2:30 AM
Quote - Only thing I could think of is to make some kind of invisible shader that picks up the shadow, and apply that to a ground plane. Does that sound right? Is there such an invisible shader included anywhere, or is that something I'm going to have to make up on the fly?
You can use Carrara's standard shadow catcher for your plane's shader.  Then add a distant light with no more than 25% brightness and turn on its soft shadows in its Effects properties.  Works great without buying a plug-in.
Miss Nancy ( ) posted Wed, 06 February 2008 at 10:52 AM
yep, I gotta admit it's a tricky problem.  if the only object in the scene is the reflecting sphere,
and there's an hdri background but no ground plane, there's nothing on which to apply the
shadow catcher shader.
noviski ( ) posted Wed, 06 February 2008 at 11:02 AM
Quote - yep, I gotta admit it's a tricky problem.  if the only object in the scene is the reflecting sphere,
You must create a Infinite Plane or Plane object then apply the shadow catcher on it.
ShawnDriscoll ( ) posted Fri, 08 February 2008 at 1:49 AM
Here's a chrome sphere on a plane using Carrara's Shadow Catcher shader.
GKDantas ( ) posted Fri, 08 February 2008 at 4:15 AM
Are you using GI in this image?
ShawnDriscoll ( ) posted Fri, 08 February 2008 at 6:44 PM
Yes.  But I'm not using the DCG GI Shadow Catcher plug-in.
GKDantas ( ) posted Fri, 08 February 2008 at 7:00 PM
How do you get Shadow Catcher to work with GI without the plugin? I did many tests here and it dont work.
ShawnDriscoll ( ) posted Fri, 08 February 2008 at 7:49 PM · edited Fri, 08 February 2008 at 7:49 PM
GKDantas ( ) posted Fri, 08 February 2008 at 10:13 PM
Ahh it works for source lights but not for HDRI light...
ShawnDriscoll ( ) posted Fri, 08 February 2008 at 11:32 PM
Just point the distant light to match the HDRI's bright spot.
Miss Nancy ( ) posted Sat, 09 February 2008 at 3:54 PM
shonner, in the above image, why is there a window reflection on the chrome sphere
where it faces the camera, but no light coming from that direction?
one would also need to blur the sphere to match the general blurriness of the hdri IMVHO.
ShawnDriscoll ( ) posted Sat, 09 February 2008 at 4:42 PM · edited Sat, 09 February 2008 at 4:44 PM
There is a much much brighter light source to the left than behind the camera.  In theory, I could have added a second distant light behind the camera.  But the sun was coming from the other window.
I could have blurred things.  I could have turned on AA.  I could have turned on Sky Light.  I could have scaled the sphere better for the room.  I could have posted this in the gallery.
But this was just a draft area render from the Assembly Room (I spent only a minute to set up the scene) to show that Carrara can do shadow catching.  The Carrara manual has two pages describing the feature.
