Tue, Nov 26, 4:53 AM CST
Subject: Looking for a hair like Mozart ...
3dvitality ( ) posted Sat, 16 February 2008 at 2:28 PM · edited Tue, 26 November 2024 at 4:49 AM
Attached Link: Example 1
 you know ...   with this "rolls"  on the side and the tail with this hair ribbon and so on ...  for David or Michael or both ...
Any advices or hints ?  found nothing here ( but don't know with wich terms I try too search ...)
Thanks in advance,
Volker
Example 2 :
Acadia ( ) posted Sat, 16 February 2008 at 6:32 PM
I've never seen anything like that around any of the Poser communities. Usually you can kind of stack hair in Poser by using one hair figure and a hair prop, but the side rolls on this hair example would be a challenge to do because to my knowledge there isn't a hair out there like that.
One option might be to use a cylinder like the one in the props primiotives folder of Poser. I would think you would need to use the cylinder template and lay the hair texture over top in such a direction that it would look like it is rolled over the cylinder.
Once done, you could place 3 cylinders on each side of the head and add the texture you made  to it in the material room. You would probably have to do some post work, but it should work.
richardson ( ) posted Sat, 16 February 2008 at 7:32 PM
noggins here or at daz. For M2. That's all I've seen.
rofocale ( ) posted Sun, 17 February 2008 at 6:42 AM · edited Sun, 17 February 2008 at 6:43 AM
You meen a hair like this? Noggins! But I had to re-texture the hair for looking like this.
rofocale ( ) posted Sun, 17 February 2008 at 6:47 AM
...another one!
rofocale ( ) posted Sun, 17 February 2008 at 6:48 AM
...last one... I think I´m gonna remake these in P7 in a near future :)
3dvitality ( ) posted Sun, 17 February 2008 at 8:40 AM
Thanx to all for reply ! I've contacted Noggins so far and get it !
