Thu, Jan 23, 7:56 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Jan 20 11:31 am)
Carrara Free Stuff here.
Subject: animated transparency map
kedo1981 ( ) posted Sat, 16 February 2008 at 6:07 PM · edited Thu, 23 January 2025 at 4:44 AM
Hello everybody
A little help if you will
I'm animating a web of paper thru a very complex path of rollers and printing modules and I want to show the paper move thru the printer as it "snakes" around rollers and such.
My idea is to use a animated transparency  map and make it look like the paper (think a strip of paper 20 feet long or so), moves thru the printer.
Any suggestions on making it work
Miss Nancy ( ) posted Sun, 17 February 2008 at 5:34 PM
yes, it should work with a square alpha map movie, in which a white bar moves from
left ot right (or v.v.).  I don't have any free time to try it myself. the other way is to
animate the UV displacement of a static alpha map, which is easy in the poser
shader tree, but I dunno how to do it in c6pro.  somebody may soon respond with
the correct technique.
whkguamusa ( ) posted Sun, 17 February 2008 at 6:38 PM
If you are not on a Mac this might help:
http://www.sparrowhawke3d.com/BeltDrivePage.html
Not sure as I have not used it myself, but the plug-in author is easy to get ahold of and very helpful to the lists.
wayne k
guam usa
kedo1981 ( ) posted Mon, 18 February 2008 at 12:18 PM · edited Mon, 18 February 2008 at 12:18 PM
The alpha channel animation is kinda working but it leaves gaps as it progresses thru the rollers. It may be due to being a single surface object.
I'm a retard when it comes to UV mapping, any tuts you know of?
AndyCLon ( ) posted Mon, 18 February 2008 at 2:49 PM
I'd recommend a very long and thin box rather than a plane for this but it should work. Don't forget the tick boxes for totally transparent in the shader.
Miss Nancy ( ) posted Mon, 18 February 2008 at 5:41 PM
post a screencap render of the gap area around the rollers, and a wireframe image of same.
I've got a feeling that it's either empty polygons, not using smart backfaces, or
the sheet hasn't got enuff polygons to support bending, meaning a 2-sided plane
will still look the same.  maybe try subdivision smoothing of 6 or more.
kedo1981 ( ) posted Tue, 19 February 2008 at 9:48 AM
BlipTV rules
Miss Nancy ( ) posted Tue, 19 February 2008 at 3:37 PM
looks o.k. to me in lo-res shock format.  that should be good enuff to show to
some corporate suits.
kedo1981 ( ) posted Tue, 19 February 2008 at 6:34 PM
If  it were only for weenie consumption I'd draw some stick figures in a power point.
But this is for field engineers and trainers.
whkguamusa ( ) posted Wed, 20 February 2008 at 3:35 AM
Maybe not what you need for your project but I just loaded up Sparrowhawk's belt plug-in.
Easy to use & works well - I think this could work for a lot of things other than belts.
http://3dsplash.com/WayneK/test/final_run.mov
wayne k
guam usa
kedo1981 ( ) posted Wed, 20 February 2008 at 7:53 AM
Thats  close to what I'm looking for, I have the wonderfull Sparrowhawk plugin, I'll need to do little X-spera-mentin to make it work.
MarkBremmer ( ) posted Fri, 22 February 2008 at 6:27 AM
 This does work quite well with an animated texture map as well. The best modeler for this will probably be the spline modeler since it takes some of the UV variables out of the process. I can show an example if its helpful.
kedo1981 ( ) posted Fri, 22 February 2008 at 9:43 AM
Looks like I may figured it out
I'd played around with  the spline modeler and noticed that it did what you said with the uv mapping.
Part of the problem is the path is very complex and, web of paper moving through dozens of convoluted twist and turns.
So I needed to be able to use an image of the roller layout to match the paper path., Vertex modeler does it, spline don’t.
**The fix: Use Abode Illustrator to   layout the path on a image layer and import the AI file into the spline modeler.  **
MarkBremmer ( ) posted Fri, 22 February 2008 at 9:55 AM
 That's what I'd do. :) No reason not to use Illustrators excellent drawing tools to create that!
