Wed, Jan 22, 8:57 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 22 5:13 am)
Subject: getting lights to follow main camera
otherworldpro ( ) posted Thu, 21 February 2008 at 3:41 PM · edited Wed, 22 January 2025 at 8:50 AM
I searched for quite a while before posting, apologies if this is in here somewhere.  I want to get my lights to rotate with the main camera when I move it, like the default poser 7 light set.  I have purchased lights that I want to move as I move the camera.
thanks
PhilC ( ) posted Thu, 21 February 2008 at 4:06 PM
Select a light
Open the properties palette
Change it to be a spotlight
Set Parent button now becomes available.
Set parent --> Main Camera
Set the light type back to what you had it originally.
Repeat for the other lights.
If you have the Poser Tool Box this is available as a one click button the the Light Tools section.
Angelouscuitry ( ) posted Thu, 21 February 2008 at 8:54 PM
I do this all the time!  Ockham has a free python script called LightPanel.py; that will just parent all the lights, of any type, all at once.
otherworldpro ( ) posted Fri, 22 February 2008 at 12:02 PM
Quote - Select a light
thanks for the input Phil, I don't have the Poser Tool Box, may one day - did purchase WW2 though, great work!!!
Anyway, can I do this with infinite lights?
Quote - I do this all the time!  Ockham has a free python script called LightPanel.py; that will just parent all the lights, of any type, all at once.
searched for this script in the free stuff, but could not find it-is it here somewhere?
thanks
PhilC ( ) posted Fri, 22 February 2008 at 12:06 PM
Yes, you can do this with any light type. The point to note is that you need to set it to be a spotlight to enable the "Set Parent" button. Then once set you can set the light back to any type you like.
Angelouscuitry ( ) posted Fri, 22 February 2008 at 12:34 PM
[Ockham
](http://www.renderosity.com/homepage.php?userid=26668)Ockhams' Free Python Scripts
[LightPanel7.PY
](http://ockhamsbungalow.com/python/LightPanel7.zip)
otherworldpro ( ) posted Sat, 23 February 2008 at 11:44 AM
**thanks  Angelouscuitry!!!
