Mon, Nov 25, 3:59 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: help - Ockham - Jiggle script P7 - location of poser.ini
markschum ( ) posted Tue, 26 February 2008 at 9:07 PM · edited Mon, 25 November 2024 at 3:39 AM
Hi all,
I didnt see this anywhere else .
The jiggle script tries to access poser.ini in the program folder and not the application data ./ poser 7 folder.  I made a change to fix it for a friend by simply hardcoding his folder path .
Is there an elegant way in python to access the windows variable for that folder path . ?
No hurry with it .
thanks
svdl ( ) posted Tue, 26 February 2008 at 9:20 PM
There is. Import the os module, and use os.environ["APPDATA"]
You'll have to append "/Poser 7" to the result.
My gallery   My freestuff
markschum ( ) posted Tue, 26 February 2008 at 11:50 PM
cool, thanks
