Sat, Nov 9, 8:26 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 08 10:28 pm)
Subject: Is there a way to create morph targets with cloth simulation in poser
snakegrab ( ) posted Sun, 02 March 2008 at 2:21 PM · edited Fri, 08 November 2024 at 1:04 AM
Online Now!
I have been trying to create a morph target for a clothing character. I export the element (It is the hip of a skirt in this case)  re-import and run the simulation with a character and scene All this works fine but when I attempt to export as a morph target and import as a morph target for the original clothing character I get the original form of the mesh without any of the morphed changes.  I can't imagine that I'm the first person to try this so if someone can point me to a tutorial or such it would be much appreciated. T
steveshanks ( ) posted Sun, 02 March 2008 at 3:04 PM
Should work.......Try this, Conform the skirt, select the hip and enter the cloth room, run the simulation then export the hip section but when you get to the "export options" box uncheck ALL the boxes, (thats in P7 others should be the same i think) now reload your skirt and try the morph.......BTW if you get tool collection from the store here you can export the body then load the morphs in one go, saves you adding morph targets by hand..........Steve
wus ( ) posted Sun, 02 March 2008 at 3:10 PM
no need to export again. click 'spawn morph target' in the object drop-down panel.
