Forum Moderators: Staff
MarketPlace Showcase F.A.Q (Last Updated: 2025 Feb 17 3:50 pm)
Looks really good hon! congrats on your new release!!
---Wolff On The Prowl---
**Following on from the best-selling original Terraformers, now there's a brand new set, more realistic and flexible than ever - ** Terraformers Altitudes!
Six different morphing terrain models load into position in your scene to scale with most characters. As with the previous Terraformers sets you get plenty of morphs to change the look of the pieces, from towering eroded mountains to low smooth bumps, and you can tile textures with a twist of a parameter dial so that no matter how much you morph you can keep the textures sharp.
And with this new series comes a brand new feature to make your scenes even more realistic - height maps. As well as eighteen new basic tiling textures (that will work on all your other Terraform sets as well) each of the pieces (except the ground) comes with eight height presets, which blend two or more textures into one another, from low to high areas. All the nodes are labelled to make it easy for you to change the presets for different combinations of textures (there's some notes in the readme).
These figures are intended for use with Poser5 or higher. If you use DS or a lower version of Poser, you'll still get all the features that were in previous packs - all the morphs and the parameter dial tiling - but the altitude presets won't work. This is because they use the P5+ shader trees. Sorry :(
Featuring:
On introductory sale now at Content Paradise!
All images rendered in Poser 7 with no postwork.
