Thu, Jan 9, 3:07 PM CST
Subject: Help, trying to make a wetsuit texture
Tanker ( ) posted Thu, 16 September 1999 at 10:04 PM ยท edited Thu, 09 January 2025 at 5:47 AM
Does anyone know a good texture maker or map that shows where exactly specific parts end and begin? I have been trying to turn the catsuit template into a good wetsuit, with different colors, logos, etc, but the lines of distinction between body parts are blurred and indistinct when I apply the tests to the figure. I am using Paintshop Pro and Poser4. Any suggestions? thanks, Tanker
grey ( ) posted Fri, 17 September 1999 at 12:13 AM
DD made some good Tmap templates for Poser 3, they haven't been translated to Poser 4 yet.
PANdaRUS ( ) posted Fri, 17 September 1999 at 8:24 AM
My suggestion? I work in photoshop and I use layers. I don't know if that's possible in PSP but if you can do that use it. What you would do is place the base template down first and on the next layer your logos, colors, etc. Then Check them out in poser and see just where everything lands. Normally it's been my experience that the back side tends to be reversed from what you see on the map. Probably so that text you write on it can show up the correct way. If anything do seems off by a bit go back to psp and move it a bit in the proper direction checking back in poser everyonce and a bit to see if it's closer or further from where you want it. It's tedious but helps. Also once you know JUST where everything is going to land...mark the template or a layer above it so that the next time you come around to using it you can follow your guides that will tell you just where it will land. Hope that helps... PAN~
Tanker ( ) posted Fri, 17 September 1999 at 9:45 PM
Thanks for the tips, I'll give it a go and if it turns out all right, I'll post. Tanker
RJ ( ) posted Sat, 18 September 1999 at 11:14 AM
If you have a copy of UVMapper (great program, BTW) you can create a larger map that should help give some detail. Just resize the default map for the catsuit obj file. Creating a new map (rearranged) would cause problems. - RJ
