Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 16 10:02 pm)
As far as I understand it, there has to be some parent actor - look in Window -> Hierarchy Editor and see what the parent is, you can select it from Hierarchy Editor and see its properties in the Parameter Dials window (although I'm not sure if that will turn off shadow casting for the whole figure).
Unfortunately, turning off shadows for the parent or body of a figure does not affect how all of its part cast shadows. Ardvark, I hope you find a script for this, because I run into this problem a lot as well (although I've never had to flip 140 switches!).
I would also like to find a similiar script that controls "visible in raytracing" for all parts, as I seem to have a lot of clothing that won't show up in reflections unless every switch is flipped....
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2652610
See linked thread. If the scripts in it don't do quite what's needed, they can probably be adapted.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
I just bought the confetti tool over at DAZ. Wonderful product. Lots of fun. But I don't want it to cast shadows. Unfortunately, there is no "body" part, so the only way I can see to make it not cast shadows is to separately go through all 140 elements individually. Anyone know of a script which can remove "cast shadows" on an object as a whole?
thanks
