Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 05 5:33 pm)
The dress is probably not superconforming. What you can do is choose the Aiko figure's body. (Probably called "figure 1), go to the "edit" menu in the toolbar and choose "copy", and then select the dress's body, and then go to the "edit" menu and choose "paste".
You might also try injecting the parabella morphs before conforming the dress
Looks like the dresses though made for A3 were not made for your morphed, parabella figure. In order to get the dresses to fit there are 5 basic choices: Use The Tailor to transsfer the parabella morphs Use Magnets to fit Use Wardrobe wizard to fit Use Crossdresser Or finally make the dress dynamic.
Quote - thanks , you really help me. i try many options like crossdresser clothes converter wardrobe but dont work. i give up with this kind of dress, i will buy just dress with morphs
Wardrobe Wizard 2 should work. Phil has a workflow on his site of how to analyze and save a morphed figure as a single morph to be injected. In about a dozen figures, I haven't found it to fail. The problem with a figure such as Parabella which has a custom body (or at least hip) morph is that no one makes clothes with that morph. Usually, when you have a figure which is created just by dialing morphs, even if the clothing doesn't have the exact same morph, you can fake it, or just dial the morphs in the figure to fit the clothes. (For example, an A3 figure with Breast 3 dialed at 1 looks pretty similar to one with Breast 4 dialed at about .8, so if the clothes have one morph but not the other you can fiddle around with both the figure and the clothes.
Attached Link: http://www.myupload.dk/showfile/r275337ce0d.jpg
recently i buy parabella for aiko and separately the dress you can see in the picture. i want to imitate this picture. the problem is that i dont know how to conform the dress to parabella, i do that€: 1-click on figures/DAZaiko3 2-click on figures/dakotaHAIR and coform to aiko 3-click on figures/fkdesignDRESS and confor to aiko 4-click on pose/parabella head and body morno problem with the hair, but the dress is not conform to parabella
