Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Do a search for a free script called Weird Juice Drops. It's a free Poser Python metablob modeler. Weird Juice also has commercial products which apply physical simulations for water effects, I think, but I've never seen a post by anyone who's used the commercial versions.
Quote - Do a search for a free script called Weird Juice Drops. It's a free Poser Python metablob modeler. Weird Juice also has commercial products which apply physical simulations for water effects, I think, but I've never seen a post by anyone who's used the commercial versions.
Does not work in Poser 7. I have already tried it.
Poserverse The New Home
for NYGUY's Freebies
How does it fail? Could it be something as simple as the failure to import Numeric at the beginning? If so, one could presumably compensate.
Well, I just checked, and the drops.py doesn't import Numeric, but he is using .pyd files, which might restrict usage to a given build of Python, and Poser 5 uses a different version than Poser 7. Bummer. And their webpage hasn't been updated in an age-and-a-half. Presumably the script is dead. :(
http://darwin3d.com/gdm1999.htm
Worst case scenario, there's a C example at the above link which shows how to create metablobs. I suppose someone could try to recreate the wheel....
I'm sure you already tried this, but... did you check the face dot product against a control value which pointed in a known direction, and all that? I seem to recall your thread on the topic. Do you have the link to it handy? Now I'm curious....
Quote - How does it fail? Could it be something as simple as the failure to import Numeric at the beginning? If so, one could presumably compensate.
When I get home I will fire up Poser 7 and get the error. Think it was on line 45 or something. and I will post it here.
I was able to get it to work in Poser 6 sometime back and have not reinstalled Poser 6 on my system since my reinstall of OS.
Poser 6 uses the same version of Python as Poser 5, so if it's a problem with the .pyd, that wouldn't have cropped up with P6.
Traceback (most recent call last):
File "C:Program Filese frontierPoser 7RuntimePythonposerScriptsWeirdJuiceDrops.py", line 40, in ?
import DropsP5
ImportError: DLL load failed: The specified module could not be found.
Here's what I'm getting, with both default placement of the .pyd and when placing it in the DLLs folder. Python is just failing to recognize the .dll, which is different from compatibility errors I've seen. Maybe someone knows how to get P7 to acknowledge the existence of the .pyd? Or maybe this error really means to tell us that P7 Python just doesn't like the Drops5.pyd and won't read it?
P7 won't load anything compiled for P6 or P5, the C API is different between Python 2.2 and Python 2.4 (just as PYCs need replacing so do PYDs and DLLs).
Drops might work in P6 but I'm not sure it was updated for P6, and it certainly won't work in P7 (WeirdJuice didn't even do an update for MetaForm for P7, so it's not surprising the freebie hasn't been updated).
Here is what I got from drops
import DropsP5
Quote - Here is what I got from drops
import DropsP5
Like I said the PYD it's trying to load won't because it's compiled for the wrong version of Python.
If your lucky Drops may work in P6, but it definitely won't in P7.
If you have P5 (or even PP) and your wanting a static object then you should be able to export and use in P7, but otherwise your on to a loser.
I don't know if this would be capable of handling an irregular form created from metablobs (perhaps if you retained the metablob centers as points of reference), but I tested this to reverse backwards-facing polygons.
This is the script.
Edited to fix editing error in script....
This was my irregular test object. The script passed this test, at least. Save this as .obj.
Quote - Sorry, I found this thread so late. I could have saved everyone the hassle.
I wrote to those guys over in Ireland way back and months later they replied back they would not be updating the Weird Juice Drops script for use beyond Poser 5.
I had wrote them also and redirected me to Daz. Response from Daz was they would have to evaluate the program and see if it was worth updating. This was when Poser 7 came out and nothing on Daz's site about any plans.
----- Original Message -----
To: JDRedline
Sent: Thursday, June 21, 2007 11:15 AM
Subject: RE: Fw: Weird Juice drops in Poser 7
Hi JD
Drops and MetaForm aren't currently compatible with P7. I have done some work on a patch recently, but can't guarantee at this moment that it will be released.
If we do produce an update it will be announced through the usual channels and the prodcut page and site will be updated.
Thanks for your enquiry.
Bill Sheil
Weird Juice Software
That is totally different from what I was told when Poser 7 first came out.
I am looking for away to create metablobs in Poser 7.
Here is what I am trying to do: create small spheres to simulate spray of water. Sort of like a splash.
Can anyone help?
Poserverse The New Home for NYGUY's Freebies
