Thu, Feb 6, 3:40 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 05 5:33 pm)
Subject: walk designer fake step
aereo1234 ( ) posted Wed, 19 March 2008 at 11:52 PM · edited Tue, 13 August 2024 at 4:09 PM
Hi everyone. I read about this "walk designer fake step" every forum I go, but I can't find solution. Just look the gif attached and please tell me what's wrong. Figure type: aiko3. I was hoping that poser 7 just fix it, but wrong..... is the same problem in all poser's version ... is me or poser 7 is exactly the same poser 6? thanks so much :)
jerr3d ( ) posted Thu, 20 March 2008 at 12:16 AM
What you are seeing is the figures' shins bending to the side. Before you take the figure into Walk Designer, turn on "Use Limits" in the Figure drop down menu. This will keep the shin from bending to the side.
aereo1234 ( ) posted Thu, 20 March 2008 at 9:35 AM · edited Thu, 20 March 2008 at 9:36 AM
what you said dosen't work....thanks anyway. Any other idea?
jerr3d ( ) posted Thu, 20 March 2008 at 11:28 AM
here is my version Limits on, ik on, and straight to default Walk Designer setting
aereo1234 ( ) posted Thu, 20 March 2008 at 11:47 AM
 you have the same problem, its looks very ugly.  definitely this is not a solution...
aereo1234 ( ) posted Thu, 20 March 2008 at 12:39 PM · edited Thu, 20 March 2008 at 12:45 PM
If you don't see that is because you have to complete one circle at least (save the gif as infinite loop, for example). Very appreciated your reply
ratscloset ( ) posted Thu, 20 March 2008 at 12:40 PM
It is hard to tell because of the Animated Camera in Jerr3d's version. I see the camera jumping, not the figure.
ratscloset
aka John
Miss Nancy ( ) posted Thu, 20 March 2008 at 12:55 PM
philc and ockham have things to fix those IIRC.
bvh fixers.
aereo1234 ( ) posted Thu, 20 March 2008 at 1:00 PM
I mean mark "walk in place" in walk designer and then save the gif as "infinite loop" in virtualdub, for example
lesbentley ( ) posted Thu, 20 March 2008 at 5:35 PM
I think the problem is the length of the legs relative to the hight of the hip above the ground. Sometimes the walk designer seems to put the hip too low, forcing the legs to buckle at the knee.
You could try this. Reduce the yScale of the thighs to say 98%, or if that does not work even 95%. Apply the walk cycle, then in frame one rescale the thighs to 100%. The feet will probably be going under the ground now, to correct this load a primitive, parent the figure to it, adjust the hight of the primitive (in frame one only) until the feet are back on the ground, then hide the primitive.
shedofjoy ( ) posted Thu, 20 March 2008 at 6:41 PM
try turning off the IK on both legs, also if you fix the shin bending problem you can save the 30 frames of the walkcycle you have fixed to the walkdesigner folder in poses then whenever you run walkdesigner you can choose your custom walkcycle...
i will have to do a test of the A3 and walk designer to see what i come up with..
Getting old and still making "art" without soiling myself, now that's success.
aereo1234 ( ) posted Thu, 20 March 2008 at 7:16 PM · edited Thu, 20 March 2008 at 7:18 PM
lesbentley and shedofjoy, really thanks but what you said didn't work too, still ugly.... anohter idea? you can probe it  if you want... thanks
Dajadues ( ) posted Thu, 20 March 2008 at 8:16 PM
That's odd.
Makes me glad I use P5.
I can't live without Walk Designer.
markschum ( ) posted Thu, 20 March 2008 at 11:31 PM
walk designer allows you to tell it what geometry you are using , it then adjusts for the lengths of the limbs .
aereo1234 ( ) posted Thu, 20 March 2008 at 11:54 PM · edited Fri, 21 March 2008 at 12:05 AM
Quote - That's odd.
poser involution?
Quote - walk designer allows you to tell it what geometry you are using , it then adjusts for the lengths of the limbs .
..apparently for aiko 3 that means nothing......
   any tested idea please...
