Sat, Feb 8, 12:20 AM CST
Forum Moderators: Staff
Subject: wireframe rendering
memphis ( ) posted Fri, 01 June 2001 at 1:09 AM · edited Sat, 08 February 2025 at 12:12 AM
anyone know any good techniques for a fully rendered wireframe model? am using some wireframes for photoshop and flor flash --- would like to be able to have a little control over the frequency of the lines created in a wireframe
ScottA ( ) posted Sat, 02 June 2001 at 1:02 PM
You can trick Poser into rendering a wireframe picture by rendering it as an animation and setting the animation to render: from: frame 1 to: Frame1 ScottA
memphis ( ) posted Thu, 14 June 2001 at 2:28 PM
Attached Link: http://www.memphisweb.net/
next question... if i want to fade from wireframe to textured, with a smooth blend between the two -- do I need to create multiple renders of the same pose and do photoshop hacking? or is there an easier way ? For example, working left to right, the figure starts 300dpi res wireframe against a black background... gradually changing to a full high res render against same said black background... no animation, just a very high res still...
ScottA ( ) posted Thu, 14 June 2001 at 7:29 PM
As far as I know, that's the only way to do that. I've asked that same question before myself. And I always get "use two renders in paint program to create the blend effect" as the replies. ScottA
Wizzard ( ) posted Thu, 14 June 2001 at 10:59 PM
well.. you could try your hand at a texture/trans that'll simulate it.. though I imagine that it's a nightmare as there isn't any at the moment... though I did have one for the dragon...
wyrwulf ( ) posted Fri, 15 June 2001 at 11:14 AM
Nance has an image posted in the Poser forum showing how to use the texture template as a transparency map that might get you what you want. Search the archives.
