Sat, Jan 11, 10:06 PM CST
Forum Moderators: Staff
Subject: conforming - why hell...?
Black Rain ( ) posted Sun, 06 April 2008 at 6:49 AM · edited Sat, 11 January 2025 at 7:05 PM
Hi there :)
need a little help 'cause i'm not able to understand why hell a model i made conforms well in P5/P6 while it conforms weird in P7 (:
thank you in advance !
nruddock ( ) posted Sun, 06 April 2008 at 9:05 AM
Not enough information to even speculate.
You'll need to be more specific about the weirdness, or give screenshots for comparison.
Black Rain ( ) posted Sun, 06 April 2008 at 9:31 AM · edited Sun, 06 April 2008 at 9:33 AM
ok - here are some screen shots :)
P6:
this is the base to conform to
this is the obj well conforming in P6
P7:
this is the base "to conform to" before conforming
this is the conforming thing before to conform
and then after the conforming in P7...some how it disappear, if i try to set to 0 the z,x and y offsets the obj become visible but not correctly placed
...i do not know from where come those offset values....
thank you :)
lesbentley ( ) posted Mon, 07 April 2008 at 2:27 PM · edited Mon, 07 April 2008 at 2:29 PM
I don't have P7, and I don't know what's causing your problem, but the "Offset" dials are for moving the 'origin' (a.k.a. "Center Point"). P6 should really display these as well, but it's a bit flaky in that respect. Initially the values in the Joint editor should be the same as the values on the Offset dials. If you move the origin with the dials, you may have to save (either to pz3 or cr2) and reload your figure before the changes you made show in the Joint Editor.
lesbentley ( ) posted Mon, 07 April 2008 at 2:39 PM
I notice a comma "," rather than a period "." separating the numbers in the screen shots, I'm guessing in that either your operating system is set to use none English (U.S. or U.K.) notation, or your Poser version is none English. I'm wondering if there is a bug in the way P7 handles the punctuation.
Black Rain ( ) posted Mon, 07 April 2008 at 3:06 PM
my Poser versions (P6/7) are English version while WinXPro is in italian ("qwerty" keyboard).....
lesbentley ( ) posted Mon, 07 April 2008 at 4:01 PM
It was just a wild guess, it may not have anything to do with your problem, but I do remember people with English versions of P4 having problems when Windows was set to none English punctuation (or was it the other way round?).
