Mon, Nov 18, 1:17 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 17 8:56 pm)
Subject: Python Error?
trades2cash ( ) posted Mon, 07 April 2008 at 4:51 PM · edited Sun, 17 November 2024 at 11:10 PM
Could someone tell me what this error me everytime i try to run a certain python..........
Traceback (most recent call last):
  File "C:Program Filese frontierPoser 7RuntimePythonJiggles4jiggles.py", line 86, in ?
    PrfTime = os.path.getatime(PrfFile)
  File "RuntimePythonlibntpath.py", line 237, in getatime
    return os.stat(filename).st_atime
OSError: [Errno 2] No such file or directory: 'C:Program Filese frontierPoser 7runtimePrefsPoser.ini'
markschum ( ) posted Mon, 07 April 2008 at 5:00 PM · edited Mon, 07 April 2008 at 5:14 PM
start at the bottom  and work backwards .
it cant find the poser.ini file in poser 7 program folder .
in Poser 7 the poser.ini file got moved to
C:Documents and SettingsOwnerApplication DataPoser 7
The jiggles script needs to be modified to point to the new location . I changed this line  >>
PrfFile = os.path.normpath(BasePath + '/runtime/Prefs/Poser.ini')
and made the part in the brackets  to read "c:/.................../poser.ini"  the actual path of the file.
trades2cash ( ) posted Mon, 07 April 2008 at 5:38 PM
Thanks I will give it a try.
ockham ( ) posted Mon, 07 April 2008 at 11:45 PM
The latest version of Jiggles automatically looks for the P7 "poser.ini" file
in the right place.
http://ockhamsbungalow.com/Python/Jiggles5.zip
I just noticed that the 'display' part of the website
was still pointing to an older version, so I corrected that.
My python page
My ShareCG freebies
trades2cash ( ) posted Wed, 09 April 2008 at 3:47 PM
Thank you very much. I knew i had seen the newer version but i couldnt remeber where. Thats what i get for not book marking. Thanks again.
globo ( ) posted Fri, 02 May 2008 at 5:04 PM · edited Fri, 02 May 2008 at 5:13 PM
 Has anyone here an idea as to what that must be changed to on OS X?
Preferences
*Poser stores files containing preference information in the user's home directory.
This preference information includesMemory dots, Library preferences, Poser UI preferences,
and the **Poser.ini/*Poser Prefs file.
These preference files are stored in the following locations:
Windows: :Documents and
SettingsApplication DataPoser 7
Mac OS X: /Users//Library/Preferences/Poser 7/
So the path isn't even based on Poser's root directory. Has anyone on the Mac ever got this baby to work?
globo
markschum ( ) posted Fri, 02 May 2008 at 6:21 PM
You can do what I suggested in my first post and just replace the path being built with a hardcoded path to the file location.  The script appears to be using that file to determine if its work file needs to be recalculated.
