Fri, Jan 24, 7:44 PM CST
Subject: About Background color
smalll ( ) posted Mon, 07 April 2008 at 5:24 PM · edited Fri, 24 January 2025 at 7:28 PM
Hi.
I want to know the way to chaging background color.
You can see next image.
Background color is white.
(It is Cartoon w / Line )
And Rendering setting is like below.
And I rendered.
The background color is black.
Can I change the color?
Could you help me?
markschum ( ) posted Mon, 07 April 2008 at 5:27 PM
If you use the paint bucket tool you can set the background color to anything you want. It can also be set in the materials room .
smalll ( ) posted Mon, 07 April 2008 at 5:42 PM
Thanks **markschum.
I tryed.
But result is like next.
I want to change background color.
Can you help me?**
FrankT ( ) posted Mon, 07 April 2008 at 5:57 PM · edited Mon, 07 April 2008 at 5:58 PM
Online Now!
Display - Background colour - set to the colour you want and render
My Freebies
Buy stuff on RedBubble
smalll ( ) posted Mon, 07 April 2008 at 6:12 PM
Thanks **FrankT.
I tryed.
But, result is same.
Help me please...
Anniebel ( ) posted Mon, 07 April 2008 at 10:14 PM
On the Render menu, (Render>Render Settings), select the Firefly tab & on the right under Options you will see Render Over - change the selected setting to Current Background Setting.
Then when you render the colour you choose as a background with also render. You probably currently have it set to render over black.
The best & most beautiful things in the world cannot be seen nor touched... but felt in the heart.
Helen Keller
My Gallery                       My Freebies                        My Store
smalll ( ) posted Tue, 08 April 2008 at 8:47 AM
**Thanks Anniebel.
I tryed.
Next image is original.
But result is not cartoon.
Can you help me?
jfbeute ( ) posted Tue, 08 April 2008 at 10:47 AM
The easy way would be to place a box behind your character, scale it so it covers everything and give it the correct color. You might have to prevent it casting a shadow. This is also the best way to display any picture in the background (make sure to size the box properly with the same proportions as the picture). The reason for not using a square is that it may display artifacts when rendering.
Don't forget to also color the ground or use the same trick there. Some special studio background props are available (free) that provide a gradual change from floor to background, these can be useful to prevent the harsh separation that may occur.
These tricks give more control over the rendering process.
Anniebel ( ) posted Tue, 08 April 2008 at 6:32 PM
You are also only previewing, which is why you have cartoon with lines, this is a preview mode - not a render mode.
Helen Keller
SeanMartin ( ) posted Wed, 09 April 2008 at 6:17 AM
The one thing I noticed in your last render is that, yes, it's got the right background, but the "toon outline" mode wasnt checked.
Kind of like being a lab rat in a maze sometimes, huh.
smalll ( ) posted Thu, 10 April 2008 at 9:48 AM
Tnasks jfbeute.
And Dear Anniebel, SeanMartin,
I'm sorry. I do not think it is Cartoon render.
It just have line only.
Thank about your kindness.
