Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 25 6:57 pm)
Point At lines up the body's origin and end point with the object being pointed at. Heads tend to have their origin at the base of the skull but their end point is usually above the top of the head. Try using the joint editor to move the head's end point (red cross hairs), to a point well in front of the figure's face.
Probably there's an easier way but you can try this.
Set the head as IK chain.
Just add "inkyChain" sectionin in cr2 file of your figure (when you open cr2 in editor search for "inkyChain"):
inkyChain Head
off
addLink chest:1 <-write the same number as you can see at other chain links
addLink neck:1
goal head:1
linkWeight 0 1
linkWeight 1 0.2
and now go to "actor head:" section and add these lines under "useZBuffer" line:
inkyParent BODY:1<-numbers should be the same as you wrote before
nonInkyParent neck:1
Load your figure and switch IK on for the head from Figure -> Use Inverse Kinematic.
The result is nice while you don't apply some extreme poses:)
@ Adom, Good idea Adom. By the way, did you know that you don't need to edit the cr2 to add the IK chain. It can be added via a pz2 (pose) file. Each actor that is going to be a part of the chain, and also the actor that is the 'inkyParent' must appear in the file before the 'figure' section. I find that KI chains work best when there are 3 or more actors in the chain, so I have added the chest in this example.
//Head_IK.pz2
//Should work on most figures.
version
number 4.01
actor BODY
actor chest
actor neck
actor head
inkyParent BODY
nonInkyParent neck
figure
inkyChain Head
off
name head
addLink chest
addLink neck
goal head
linkWeight 0 1
linkWeight 1 0.2
The endPoint can also be moved with a pz2. Setting the endPoint is figure specific, You would usually need a different pz2 for each figure. The one below is for V3. The endpoint has been set slightly higher (at y=0.645) than the origin (at y=0.640). { //V3HeadEnd.pz2 by Les Bentley 09/April/2008. //Changes the location of the endPoint in V3s head, //for better compatibility with 'Point At'. version { number 3 }
actor head
endPoint 0 0.645 0.1
figure
By the way, it may be worth pointing out that if you are going to use a pz2 to modify an existing IK chain, different figures use different names for the IK chains, this has to be taken into account when using the pz2. The P4 figures use:
rightArm
rightLeg
Etc.
The DAZ figures use:
RightHand
RightLeg
Etc. So does Jessi.
I suspect that most if not all recent figures use the DAZ convention. These names are case sensitive. Although the names are case sensitive, Poser will always turn on leg IK for chains named "rightleg" and "leftleg" no matter what the case.
If you want the figure to load with leg IK off, in Poser turn IK off (it's IMPORTANT that you turn it off in poser), save the figure, then edit the internal names (not the display names) of the IK chains in the cr2 by inserting a space or underscore, eg "Right_Leg".
Of course you have just discovered another way to have a figure load with IK off. Don't have any IK chains in the cr2 to start with, load them from a pose file if and when you need them. I never thought of that.
Again a word of caution, you should only delete IK from a cr2 that has been saved with IK off, if it was saved with IK on, the feet may end up being displaced when you load the figure. This is to do with the fact that Poser changes the parenting and hierarchy when you turn IK off.
About the names - yes this is very confusing and can couse plenty troubles sometimes:)
The way of changing names inside cr2 to turn IK off for legs is not what I like so I was quite happy when you mentioned about pz2 file.
Fortunately the changes which are made inside cr2 after saving with IK on are not so big.
Each IK target (which is on while saving) has parent set to BODY in actor section and addChild section. That's all (I think:)
I think you will get the point. See the image above.
I don't know all the "why's" and "what if's" about this, but personally I'm not going to remove IK from figures that were saved with IK on. Note that translation and rotation data in in the legs can be different depending on whether IK is turned on or off. You may get away with it for a zeroed figure, but I would rather not take the risk. Besides it is easier to turn IK off before saving than to zero the figure, and then have to do all the extra edits.
I should have mentoined berfore that I'm talking about saving figures in their Zero position (to alter its pose I'd use pz2. That's why it didn't cross my mind to think about example as yours).
If you'll change the position of IK targets (here lFoot) and save figure (cr2) then yes you are 100% right that changing "parents" is not enough (dials that without IK are set to 0 get some value when IK is on - so that should be corrected as well -> Side -Side is a good example).
So when I said "change parent only" I meant in "Zero pose" figure:)
In your example:
And now comes the part which couses dislocation
While IK is on, the position of lFoot is controled by xyzTran (values are saved into cr2 accordingly).
While Ik is off these values are not saved (while IK is off, xyzTran should be 0 usually)
Now when you load your cr2 (which was saved with IK on) and all IK chains are removed from this figure then:
So that is why after removing IK from CR2 (which was not saved in Zero pose) it is necessary to zero xyzTran of IK targets which were moved (the other dials won't make any troubles). It could be corected inside poser if xyzTran were visible while IK was off.
But anyway this is to much troubles.
And I agree with you that it has no sense at all doing this that way since you can just save cr2 inside Poser with Ik set to off:)
And I think we are now totally off topic so just thank you for that pz2 idea from your first post.
Is there a way to make the head of a figure stay stationary ( look at camera) while the body twist? I have tried point at camera , but the head gets bent at a very strange angle. Is there a python script for this? I have also tried putting a prop (ball) in the scene, but can not find the proper placement. Thanks for any help.
skee.
NOTE: No trees were killed in the sending of this message, but a large
number of electrons were terribly inconvenienced.
