Thu, Jan 30, 11:56 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 30 7:24 pm)
Subject: Request for reference pictures of a saxaphone.
PhilC ( ) posted Sun, 13 April 2008 at 9:26 AM · edited Tue, 14 January 2025 at 11:40 PM
Hi Folks,
Does anyone possess a saxaphone and if so would they be able to take some pictures of it that I may be able to use as a reference? The over all design is straightforward it is all the keys, levers and plumbing that present the challenge.
They need not be high resolution, just several from different angles so that I can see which lever operates which key. A camera phone or web cam would be quite sufficient.
pcooke@philc.net
Many thanks.
PhilC
Daymond42 ( ) posted Sun, 13 April 2008 at 9:38 AM
I'm heading to some pawn shops today, so I'll take some pictures if I see some.
If there's one thing Orlando has a lot of, it's pawn shops. The dark, dirty, unsorted ones are always the best.. :)
Currently using Poser Pro 2012 (Display Units = feet)
AMD Phenom II 3.2ghz (6 cores)
8gb RAM
Windows 10 Pro 64bit
Gareee ( ) posted Sun, 13 April 2008 at 10:57 AM
Phil... googling saxaphone diagram gave me some pretty good images...
http://images.google.com/images?um=1&hl=en&q=saxaphone+diagram
PhilC ( ) posted Sun, 13 April 2008 at 11:37 AM
Gareee ( ) posted Sun, 13 April 2008 at 11:40 AM
And fully poseable, riiiight?
I can't believe there isn't a poser saxaphone already somewhere, even if somewhat inaccurate.
PhilC ( ) posted Sun, 13 April 2008 at 11:43 AM
I'm sure there is.
This one has to be accurate and poseable :)
Acadia ( ) posted Sun, 13 April 2008 at 12:11 PM
There used to be one at 3D Cafe.
pakled ( ) posted Sun, 13 April 2008 at 1:23 PM
Try Selmer, they make saxaphones. Any company that does brass and woodwinds should have a beauty shot or two.
I made a Seaxophone once, partially modeled on a sax I had at the time (sort of a weapon...;) 3d Cafe did have one. I've seen others in the galleries over the years...
HAWK999 ( ) posted Mon, 14 April 2008 at 12:41 AM
 Hi Phil.
I have a tenor and alto saxophone which I play with.
The tenor I have had for 35 years give or take.
I'd be more than happy to take hires picture for you this week if you still want them.
I have a 10.2 meg Pentax and the files can be quite detailed.
Jean-Luc
PhilC ( ) posted Mon, 14 April 2008 at 5:44 AM
Thanks, yes that would indeed be helpful. They do not need to be high resolution 600 x 600 @ 100 KB will be fine. I just need to be able to see how the keys and links are connected.
Again thanks,
Phil
PhilC ( ) posted Mon, 14 April 2008 at 6:30 AM
Cool, :)
I'll be able to use all of the above and start on it today.
Many thanks to all.
