Sun, Feb 2, 11:49 AM CST
Forum Moderators: Staff
Subject: Crosstalk
Sabou ( ) posted Tue, 22 April 2008 at 4:56 AM · edited Sat, 18 January 2025 at 9:43 PM
I tried to make one of my shirts working with crosstalk.
This works very well, but the FBM then did not work any more. So i must go to the single body parts to change manually.
Is this allright? Or is there an error in my cr2?
Someone here who know this problem?
svdl ( ) posted Tue, 22 April 2008 at 11:06 AM
This is well known ERC behavior.
There is a way to fix it (needs some work, however). What you have to do is create a second FBM dial on the body with a different internal name.
Example: the ShouldersThickness morph. You will have this code in your CR2:
actor rCollar:1
    channels
        targetGeom PBMShouldersThickness
            valueOpDeltaAdd
            Figure
            BODY
            deltaAddDelta 1.00000
Now add a second block of ERC slaving code
            valueOpDeltaAdd
            MyShirt                            //the name of your figure, NOT Figure, or Figure 1
            BODY:1                          // include the number, unlike in the previous block
            PBMShouldersThicknessLocal      // the internal name of the extra FBM
And in the BODY actor, create a second set of valueParms with the same names as the original FBMs, but with "local" appended to their internal name:
        valueParm PBMShouldersThicknessLocal
            name ShouldersThickness
Lastly, hide the "original" FBMs in the BODY actor.
Should do the job.
Another option might be using linkParms statement in the Figure section. linkParms is an older way of slaving morphs to FBM dials, with much less control (you cannot change the valueOp type or the detalAddDelta value), but with the advantage that it never crosstalks - linkParms only work within the same figure.
My gallery   My freestuff
Sabou ( ) posted Tue, 22 April 2008 at 12:18 PM
Wow, okay, i try it. Thank you very very much.
