Thu, Nov 14, 6:50 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 14 4:48 pm)
Subject: Is there a program you can Put all frames from poser into and add Audio ect?
Lady Cherry ( ) posted Fri, 17 September 1999 at 11:24 PM · edited Thu, 14 November 2024 at 6:42 PM
im looking to get a program that extends the amount of frames or i can add the frames from poser into. Being able to add audio ect unless anyone knows another way! Thanks for your time! This place is wonderful by the way i love all the people here and the help i recieve when i ask just wanted to say thanks ahead of time!
The Art Door and Rendervisions Community.
For Artists By Artists
Xurge ( ) posted Sat, 18 September 1999 at 12:19 AM
By your description it looks like you need something like Adobe Premiere 5. Here you can edit the avi. files put them together to make longer movies and you can also add as many audio tracks as you want. Good Luck.
Dr Zik ( ) posted Sat, 18 September 1999 at 8:18 AM
Hi Folks! Lady Cherry, You might also take a look at Adobe After Effects (the latest version is 4.1). I find it handles placing and manipulating still images and audio a bit more fluidly than its brother Premiere, which I tend to use more for simply splicing movies together. After Effects also allows you to create special effects to your movies using Photoshop filters and layers, although I think the latest version of Premiere now allows you to use Photoshop filters and plug-ins. If you're willing to do a little bit of digging--and if you're using a Mac--there's a neat little program that provided some decent movie and sound editing features at a fraction of the cost and RAM requirements of Premiere and Avid Cinema. It's called QuickFlix! and was made by the old Radius Co. My version still runs pretty well, even on OS 8.5; check out some of online boards or do a QuickFlix keyword search and maybe you can locate a copy. Hope this helps. Peter (Dr. Zik)
Lady Cherry ( ) posted Sat, 18 September 1999 at 9:53 AM
Floydd ( ) posted Sat, 18 September 1999 at 10:44 AM
As you seem unusually well informed on the video gig, permit me to address the following your direction. With the universe of great free stuff out here I guess I've gotten spoiled. If not looking for 30fps NTSC video output, have you seen a good freeware utility that will allow you to compile & sync some type of sound files & some type of motion pictures at some resolution or frame rate? An AVI or MPEG or Quicktime freebee that will work without fancy (couldn't spell "high-fullootin") graphics cards? OR, have I just overlooked the obvious somewhere? Something already in Windows or an Adobe app?
Dr Zik ( ) posted Sat, 18 September 1999 at 3:55 PM
Hi Folks!! floydd, you flatter me more than I deserve. There's a good bit of stuff out there--lemme give it some thought for a day or so. The timing of your question is actually good 'cause I'm researching that sort of stuff for fall classes. I'll post an answer here at the Forum or you can converse with me directly. My e-mail is DrZik@aol.com Peter (Dr. Zik)
Xurge ( ) posted Sat, 18 September 1999 at 4:49 PM
Another app. that could be of use would be Avid Cinema. It also lets you play arround with movie files and audio. It is not as costly as Adobe Premiere or After Effects. Good luck Xurge
PANdaRUS ( ) posted Sun, 19 September 1999 at 8:10 AM
Well I was going to add my two cents in here regarding Adobe Premiere 5.1a (my currently owned version) but since you've all got it under wraps...I'll save my money..haha. Just so you know though..if you're not planing on being serious with your avi's I wouldn't go with Premiere..it set me back $457 personally. So you might want to think about what you actually will use the software for in the future and that might help in deciding what you need best. PAN~
SewerRat ( ) posted Sun, 19 September 1999 at 8:30 AM
floydd: why do you want to limit the animation to 30fps? If you get television quality on the computer it looks kinda ugly. You don't need to limit the framerate to capture to television either, whatever equiptment is capturing should do that (ok, I lie. I have to reduce my monitor refresh rate to 50hz...but that doesn't have anything to do with the animation file) or am I answering the wrong question? SewerRat
Dr Zik ( ) posted Mon, 20 September 1999 at 8:42 PM
Hi Folks!! floydd, SewerRat makes some good points. Most of my animations (I'll show them somewhere soon, I promise!) are currently rendered at 15fps, although I admit that their ultimate destination is CD-ROM. By the way: you should check out > Download.com < frequently for Mac or PC shareware and freeware that might give you some basic moviemaking abilities on your computer. I'll keep checking for other sources, and of course you can e-mail me if you want to talk more one-on-one. Peter (Dr. Zik)
Floydd ( ) posted Tue, 21 September 1999 at 12:52 AM
Thanks for the suggestions. I'll look around. S.R. - my whimpy-puter won't handle 30fps so it's not a program requirement for my use. -floydd
