Sat, Jan 11, 12:28 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: Looking for a script to add new channels
alizea ( ) posted Sun, 23 March 2008 at 9:08 AM · edited Sat, 11 January 2025 at 12:22 PM
Hi everybody !
I'm looking for a script that add new channels into several bodyparts of a figure that doesn't  have any " free" channels . I would like to use those channels to inject a custom morph , and I'd like to be able to distribute them .
 ( I'm working on AS Little Dyvil dress , and some cr2 hairs too )
Thank you for your help .
Alice's and GND4's Tailor !
Check my free clothing fits : www.alizea3d.com
svdl ( ) posted Sun, 23 March 2008 at 10:19 AM
file_402601.txt
Here you go:
My gallery   My freestuff
alizea ( ) posted Sun, 23 March 2008 at 11:48 AM · edited Sun, 23 March 2008 at 11:49 AM
SVDL , you made my day ! It works just great !
Do you allow me to include your script in my morph pack , please ?
svdl ( ) posted Sun, 23 March 2008 at 12:40 PM
Sure. Whipped it up in five minutes, there's no real effort invovled from my part.
alizea ( ) posted Sun, 23 March 2008 at 1:41 PM
Thank you once again . Maybe it's not a big effort for you now , but you have surely several years of efforts behind you in learning . Thank you for sharing your knowledge .
RAMWorks ( ) posted Tue, 25 March 2008 at 12:13 AM
Is there a way to add LOTS of blank channels to a cr2??  A gal is working on getting the Zygote Centaur up to speed by creating LOTS of morphs for him, face and body and needs a way to get as many as she needs with no limitations.  She really needs help.  I'm a part of the team that's working on this project so I thought I'd do a bit of research or ask around.  I searched and found this thread.  Seems easy for some but it's a complete mystery to many!!
Any help is greatly appreciated!!
All the best
Richard ;-)~
---Wolff On The Prowl---
My Store is HERE
My Freebies are HERE
svdl ( ) posted Tue, 25 March 2008 at 1:38 AM
Attached Link: http://www.svdlinden.nl/webposerstuff/downloads/createmultipleparameters.zip
Here you go.
You've got two possibilities here.
"CreateMultipleParametersEmbedded.py" has the names of the parameters in a list in the source file. You can easily edit the source file and replace/add names as much as you want.
Or you can use "CreateMultipleParameters.py" that loads them from a text file. Not meant for end users, but could be handy for developers. A sample text file is provided in the zip.
svdl ( ) posted Tue, 25 March 2008 at 1:57 AM
Attached Link: http://www.svdlinden.nl/webposerstuff/downloads/createchannelscript.zip
Did some rethinking on the purpose of the script, and came up with something better: a script that creates a script. Sounds complicated, but it's not.
Heres how it works:
  • you make a text file with the names of the channels you want. Each channel on its own line in the textfile.
  • then you start Poser and run the script "CreateChannelScript.py". It doesn't matter whether a figure is loaded or not.
  • The script asks you for the file name of the text file with the channels.
  • Then the script asks you for the file name of the channel creation script you want to make. The .py extension is optional.
  • And then "CreateChannelScript.py" creates the script for you. The script it just created then can be distributed with the rest of the product (in this case the Zygote centaur).
RAMWorks ( ) posted Tue, 25 March 2008 at 9:07 AM
Thanks so much!  Kattey will be very happy I think!! 😄
My Store is HERE
markschum ( ) posted Tue, 25 March 2008 at 10:58 AM
A channel will be created as a morph is loaded to the figure .  I dont know what the restriction would be on distributing a new cr2 ?
svdl ( ) posted Tue, 25 March 2008 at 11:40 AM
Quote - A channel will be created as a morph is loaded to the figure .  I dont know what the restriction would be on distributing a new cr2 ?
No problem at all. The new cr2 can contain just a readScript statement that reads in the existing cr2, and have the additional channels (problem is that the existing cr2 must be at a fixed location),
or the script can be invoked using a pose file to add the channels to the "old" cr2 the user already has to have in his/her posession.
The second option is probably better, since it doesn't require the original cr2 to sit in a certain predefined folder.
Kattey ( ) posted Sun, 30 March 2008 at 10:47 AM
Svdl, I'm that girl that asked for the script. Thank you very much, it is working very nicely and a huge timesaver!
lesbentley ( ) posted Sat, 03 May 2008 at 10:44 PM · edited Sat, 03 May 2008 at 10:49 PM
These scripts don't work correctly for me in P6. With the "createMultipleChannels.py" I get the error:
Traceback (most recent call last):
  File "", line 20, in ?
AttributeError: CreateFullBodyMorp
And with the "createMultipleChannelsEmbedded.py", I get the error:
  File "", line 24, in ?
With the script generated by "createChannelScript.py", I get this error:
  File "", line 22, in ?
All scripts make one targetGeom channel in each actor, but no valueParm in the BODY.
[edit]
P.S. I just noticed the error says "Morp" not "Morph", don't know if that is significant.
nruddock ( ) posted Sun, 04 May 2008 at 5:52 AM
Quote - These scripts don't work correctly for me in P6.
The CreateFullBodyMorph is P7 only.
Quote - I just noticed the error says "Morp" not "Morph", don't know if that is significant.
Don't think so.
Photopium ( ) posted Mon, 08 December 2008 at 8:34 PM
SVDL- Cannot seem to download from your site, will you let me know when it is back up?  Would really like the script!  thanks.  -WTB
markschum ( ) posted Sat, 08 August 2009 at 3:50 PM
SVDL, any chance of getting the two scripts for multiple channels ?
or anyone who has them could send me a copy ?
thanks
jasmineskunk ( ) posted Sun, 20 December 2009 at 9:39 PM
Can I necromance this thread?
I need exactly this...
a way to add channels to a figure that doesn't have empty channels so I can distribute morphs I have made to others.
I tried the .pmd inj method and it works ok, but I am really wanting to make this available to the whole Poser/Daz community, so I am really struggling to understand all of this stuff.
I have found tut's to tell me what to do after I get the blank channels in there, but although, I did get the script (above) to work, I had no idea what to do with it.
Can someone help me understand?
Thanks,
Jasmine Skunk
