Your very welcome. I am trying to figure out a way to load 'multi sub object' textures from one Poser figure onto another in Max. Similar to MAT files in Poser. For example.... In the image above, i used syyd's Kane texture. I load my Poser scene into Max and set up the textures as I would in my tutorial. I should then be able to save my 'multi sub object' texture to the Max material library, which I can. I should then be able to load that same Max texture onto any other Michael figure contained in a poser scene in max. But I can't. the textures load into the material editor ok, but they are not landing on the model correctly. Anyone got any idea's????
Thanks for the tip Polartech. I was going to get MaxPose, but then the PPP came out. I have been experimenting with saving and laoding the textures from one model to another. the head maps fine, but the rest of the figure is all wrong. I think it's something simple, but it's just trying to find it. Thanks, Colm...
Attached Link: http://www.renderosity.com/~syyd/pntuts/posermax/
Hi everyone. I have just added a new tutorial to our PosaNation site called: Advanced Texturing Of Poser Scenes In 3D Studio Max 3.1 With The Poser Pro Pack Plugin. You can access it here: http://www.renderosity.com/~syyd/pntuts/posermax/ or from the tuts section here on RR. Basically, I struggled for a while trying to create better poser renders in Max. Which was pretty easy with the Pro Pack plugin. But, I wanted to access the individual textures assigned to the Poser material groups in Max via the 'Multi Sub Object' texture editor and do stuff like adding multiple textures to one Poser group. Like having dirt on parts of the figure, via the free 'Dirt' plugin from Blur Studios. This leaves us Poser/Max users with endless possabilities. The tut I think is quite easy to follow and it is really just a matter of clicking the right buttons. Hope it helps some people.
