Sun, Feb 16, 11:19 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Feb 13 6:48 pm)
Carrara Free Stuff here.
Subject: Multiple shaders not displaying in texture room under NT
october ( ) posted Sun, 17 June 2001 at 4:31 PM · edited Fri, 27 December 2024 at 1:37 PM
I've had this problem for some time now but it never interfered with my workflow 'til now. Under NT I can only see one shader at at time in the texture room, like wise in the render room I only see one image at a time and in the model room I only see one fire or cloud object at a time. Back when I was on W95 I didn't have this problem I could drag a channel from one shader and drop it in another. I don't remember if it ever worked on under NT, I think it did once but I don't remember. I did though have to reinstall once and I don't know if that did it, I can only vaguly remember how the install routine goes you get the option for some kind of cursor control and mayber open GL support, or was that Bryce?? I'm using a Dell Workstation 420 wtih an Evans and Sutherland AccelGalaxy 2100 video card which I've changed all the options for one at a time. I'm lost, I'd like to be able to see the shaders so I can drag and drop between them. Any ideas?
october ( ) posted Sun, 17 June 2001 at 8:06 PM
Thanks for your reply, I'll try to explain my sitution better. I am talking Carrara, the setup options only appear if you choose custome (if I remember correctly of course.) On W95 I was able to have 2 shaders open in the texture room at the same time and see them both and drop and drag between them. But now on my NT machine I only have access to one shader at a time in the texture room, although it looks indeed like I do have multiple shaders open for they appear in window menu. When I use the window menu the positions of the shaders I'm working on change as if I had invisible overlapping shaders open, I just can't see them at the same time. Am I making any sense, should I start over trying to explain? Thanks.
october ( ) posted Sun, 17 June 2001 at 8:22 PM
Since I'm having trouble explaining it I've decided to upload a screen shot. I just installed Carrara on my 98 machine, this is taken from the shader room with two shaders open you can see both of them. On my NT machine I can only see one at a time.
october ( ) posted Sun, 17 June 2001 at 8:41 PM
That's awfully generous of you, thanks! I'm hoping that the pending patch will clear things up though. If not I'm gonna un/reinstall, but I'd hate to have to dig through my HD to reload all my extensions and shaders! Later.
october ( ) posted Sun, 17 June 2001 at 9:57 PM
It's all solved, it wasn't a problem at it. Just my bleeding oversight! Under the winodw menu is an option... Single Window Mode Guess what it does.. :) Sigh, I hate when I miss something so simple, to think all this time... ahwell live and learn. Don't be too hard on me. Off to shader land!!! Later.
Tuck3D ( ) posted Mon, 18 June 2001 at 12:08 PM
You will beaten and horse whipped.Assume the position!! Dont you just hate it when it's just so simple.
