Carrara F.A.Q (Last Updated: 2025 Jan 10 10:15 am)
Hi Pinklet,
You're running a Mac, right? I'm not having any issues here on this Mac Platform.
Usually issues like that can be object/shader specific and can be fixed. Sometimes it's as easy as rebuilding the shader itself. If you're cranking up the photon settings, sometimes in combination with other shader settings, they fight each other.
If the objects causing the issues, open it in the vertex modeler and make sure that it doesn't have bad topology/mesh closures.
As always, maker sure that you're also running the latest version of Carrara - 6.2
Mark
Thanks Mark,
It should be simple to figure out. It's a model of a bottle using the "replicator" feature. The funny thing is that it renders half way, so I am puzzled. But the caustics would be rendered on to the floor of my seen, I think that is where it crashes. I will attempt to render the object with out replication, and trouble shoot it from their.
Thanks again Mark.
Never rendered this way with caustic, but you can also try to convert the replicated object to realinstance, will eat a lot more memory but meybe dont crash.
Follow me at euQfiz Digital
Cool image, maybe was the number of replications that cause the crash...doing and learning!
I can not render a file with caustics. It will render without them, but when I enable them, it simply crashes. Any tips?
Again I am not using this software as a hobby, I need to meet a deadline and this software is proving unreliable. I would appreciate any help.
