Fri, Feb 27, 3:41 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2026 Feb 26 11:25 am)
Subject: V4.2 & morphs++ ?
jerr3d ( ) posted Mon, 19 May 2008 at 11:37 PM · edited Fri, 27 February 2026 at 9:23 AM
I installed V4.2 into Poser 7 and then morphs++ I assume the idea is to just install the morphs you want to use onto your V4 character, from the Pose Morph Injections library. So i tried injecting one of the characters "Emma" and i get no results. There is no Emma morph in the V4 Body or Head Parameters AAAAAAAAAAAHHHHHHHHHHHHHHH!!!!!!!!!! thank you ^ ^
Acadia ( ) posted Tue, 20 May 2008 at 12:02 AM
With V4.2 you need to inject the figure's morphs before you inject the character morphs.
Attached Link: April's free V4.2 and A4 Morphs ++ loaders
There is a file at the above link that has  2 useful cr2s from April that will load V4.2 with V4.2 Morphs ++. Scroll down the page to find them.
Also, you can load V4.2, inject the figure morphs, and then click the + sign at the bottom of the library and save that morph injected version of V4.2 to your library. Give it another name IE:  V4 morphed.
Then when you want to use V4.2, select that morphed figure, then you can just INJ the character morphs without having to worry about injecting the figure's morphs again.
jerr3d ( ) posted Tue, 20 May 2008 at 12:25 AM
thanks ^ ^ i appear to have my Base V4.2 morphs loaded
jerr3d ( ) posted Tue, 20 May 2008 at 8:32 PM
found the prob i guess V4.0 did not want to go easily after i uninstalled her V4.2 worked fine i had never installed V4.1
odeathoflife ( ) posted Tue, 20 May 2008 at 8:43 PM
did you initialise everything?
♠Ω Poser eZine Ω♠
♠Ω Poser Free Stuff Ω♠
♠Ω My Homepage Ω♠
www.3rddimensiongraphics.net
jerr3d ( ) posted Tue, 20 May 2008 at 8:47 PM
ya ! ^ ^
