Sat, Jan 11, 7:00 AM CST
Subject: Conforming Clothing: Help Needed
Molina00 ( ) posted Sun, 25 May 2008 at 6:25 PM · edited Fri, 10 January 2025 at 1:14 PM
I finished modeling my first major piece of what would be conforming clothing (big accomplishment for me), and an even bigger accomplishment is that I managed to group it and play with the CR2 to get it to conform properly (for the most part).
But anyway, everything seems to conform okay (for a first timer) except the cuff on the sleeve.  I think it may be a problem with my grouping (done in Blender) but I tried regrouping the area two or three times and haven't manage to get rid of the distortion.
The distortion in the render occurs when I bend the forearm.  It conforms fine when I use side-to-side and twist, but it gets messed up when I bend.
If anyone has any thoughts or suggestions I would very much appreciate it.
Thanks.
adp001 ( ) posted Sun, 25 May 2008 at 6:46 PM
Check the joints for the forearm(s).
PhilC ( ) posted Sun, 25 May 2008 at 6:48 PM
It is most likely that all you'll need to do is make a very small adjustment to one of the joint spherical fall off zones. Difficult to explain, easy to show in a video tutorial. If you would like to go to the link below, scroll down the page and you'll see links to the videos.
http://www.philc.net/tutorialsIndex.htm
Hope that helps.
Molina00 ( ) posted Sun, 25 May 2008 at 7:56 PM · edited Sun, 25 May 2008 at 7:57 PM
Quote - It is most likely that all you'll need to do is make a very small adjustment to one of the joint spherical fall off zones. Difficult to explain, easy to show in a video tutorial. If you would like to go to the link below, scroll down the page and you'll see links to the videos.
Hope that helps.
Thank you so much sir.  Those joint parameter tutorials turned out to be just what I needed.
Looks much better without a shark fin coming out of the sleeve.
Molina00 ( ) posted Thu, 29 May 2008 at 4:45 PM
I need some more help it seems.  I more or less finished modeling the second piece that goes with the costume I am making.  I set it up pretty much the same way as the first piece in terms of grouping, editing the CR2, etc.  However it does not show up in Poser when I load it from my library.  The figure name shows up as having been loaded but the figure is nowhere to be seen.  Checking reverse normals doesn't work.  Any help would be great.
Thanks.
PhilC ( ) posted Thu, 29 May 2008 at 5:16 PM
Check the group names in the OBJ file and ensure that they exactly match what is in the CR2 file.
Molina00 ( ) posted Thu, 29 May 2008 at 9:01 PM
From what I can see, they seem to match.
EnglishBob ( ) posted Fri, 30 May 2008 at 4:31 AM · edited Fri, 30 May 2008 at 4:31 AM
They do have to match exactly - Hip is not the same as hip, for instance. Letter case is important.
Molina00 ( ) posted Fri, 30 May 2008 at 2:22 PM
I don't think letter case is the problem.  It looks like I named them the same as in the Cr2.
Additionally, I did a little remodeling on my original piece that did work okay, didn't change any of the group names, but the revised version doesn't show up in Poser either.  ???
EnglishBob ( ) posted Sun, 01 June 2008 at 4:36 AM
Would you be willing to send your files to someone else (me, for instance)? That may be the easiest way to get to the bottom of this. I'd promise not to redistribute them, of course.
Molina00 ( ) posted Sun, 01 June 2008 at 10:20 AM
Quote - Would you be willing to send your files to someone else (me, for instance)? That may be the easiest way to get to the bottom of this. I'd promise not to redistribute them, of course.
Thank you for the offer.  I just sent my files to PhilC this morning though so hopefully he can help me figure out what's wrong.
I wouldn't be too worried about redistribution anyway, since it is part of a character set I wanted to make available as a freebie in the first place.  That is assuming I can get it all working properly.
