Fri, Nov 8, 4:29 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 08 8:41 am)
Subject: Poser fusion for C4D
bishop666 ( ) posted Thu, 05 June 2008 at 11:28 AM · edited Fri, 08 November 2024 at 4:19 PM
 Hi:
I have been attempting to import a Poser Pro figure into C4D R10.5 (mac OSX) using the Fusion plugin but each time I specify the figure C4D crashes.  Am I missing something or should I forget about the plugin and stick with IPP which, by the way, is a great plugin?
Thank you in advance.
wdupre ( ) posted Thu, 05 June 2008 at 12:54 PM
why use fusion if you have IPP? IPP imports a fully rigged character, it will import almost any poser file with virtually as many features as Poser. Fusion imports a frozen mesh (or a sequence of frozen meshes in the case of animation). this is the primary reason I didn't see any reason to buy PoserPro because I already have a much more capable solution for C4D.
CuriousGeorge ( ) posted Thu, 05 June 2008 at 1:43 PM
From what I've seen, IPP is definitely the superior product to Fusion
bishop666 ( ) posted Thu, 05 June 2008 at 2:46 PM · edited Thu, 05 June 2008 at 2:47 PM
Quote - From what I've seen, IPP is definitely the superior product to Fusion
I suspect that you are correct in your above opinion and I plan to continue to use IPP, however, I made the, perhaps, misguided decision to upgrade to PoserPro and since it includes Fusion I set out to test its funtion, which, at the current time is nonexistent for me.  In addition, with the exception of the aforementioned plugin and PPro's ability to render in a 64bit environment, I fail to see the difference between PoserPro and P7.
Well, it will not be the first time that I have made a purchase based upon hype rather than reality.  So, I guess that I will continue to use either P7 or PoserPro for character creation, IPP to import into C4D and VRay for render.
Thank you both for your input.
P.S. I might mention that support, although quite timely in their response, has not yet provided a viable solution to the Fusion debacle.  They did, however, imply that the coexistence of "another Poser hosting plugin" might be responsible.  I can only assume that IPP might represent that "other hosting plugin," and I am not about to delete it!
