Thu, Jan 23, 11:11 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 23 9:03 pm)
Subject: How do you stop pixelated images when rendering?
homeriscool ( ) posted Thu, 05 June 2008 at 5:39 PM · edited Tue, 30 July 2024 at 7:41 AM
hi there, i have noticed with my latest image that when i zoom in it is very pixel dotted - as if when it has been rendering little dots appear as if the image has little dots of "ink" missing from the final image. has anyone else ever had this and how do you combat it? thanks.
Acadia ( ) posted Thu, 05 June 2008 at 5:42 PM
Can you post a screen capture of what you mean?  Also can you post a screen capture of your render settings?
homeriscool ( ) posted Thu, 05 June 2008 at 6:03 PM
sure here they are - thanks for your help.
and heres the settings-
Acadia ( ) posted Thu, 05 June 2008 at 7:00 PM
I don't know why you want to zoom in on whatever it is that you are rendering, but perhaps try these render settings.
The bucket size is variable and can be adjusted by values of 8 if you need to lower or increase the value.
replicand ( ) posted Fri, 06 June 2008 at 2:34 PM · edited Fri, 06 June 2008 at 2:35 PM
Try:
  • MinShadingRate: 0.2 is a very popular setting here but I usually use 1
  • Pixel Samples: 9. Will be pretty slow but edges will be very smooth
  • Post Filter Size: 4
  • Post Filter Type: Sinc. Your image will be very crisp; Gaussian / 3 will look more like film
There is a huge anti-filter bias in the forums, so most people leave theirs set at Box / 1, which is about the worst filter setting you can use especially since you can't turn off the filter. Blurs everything indiscriminately.
YngPhoenix ( ) posted Sat, 07 June 2008 at 2:11 AM
One other thing you might check on is the texture itself. If it's supposed to be a solid color then open it in any image software you may have and zoom in on it several times to see if you notice any spotiness or dots or weired pixels.
