Thu, Jan 9, 12:05 PM CST
Subject: Dose Poser have third party effect?
smalll ( ) posted Sat, 07 June 2008 at 6:31 AM · edited Thu, 09 January 2025 at 12:53 AM
Hi.
I have a question.
For example, the smoke when tank shoot the target.
I think there is not any flame in poser.
Dose poser can make disppear model slowly?
I think it is better making in Adobe AfterEffect or premere.
It is just question of begginer of poser.
Good bye.
Jestertjuuh ( ) posted Sat, 07 June 2008 at 6:48 AM
I think with disapear you mean that a model fades away in a animation?
I dont have done much with poser animations so I leave that question open for the animation guru's.
For a gun flash, you can use a prop.
I think this will work in animations to, just experiment with size etc.
Smoke should work to.
As example you can find a muzle flash prop here.
Download the prop and pick it apart to see how they did it.
This should give enough information to create your own flash/smoke prop.
Or just use it as it is.
I hope this helped a bit.
I am not a complete idiot, some parts are missing :)
To go to my home page, click the banner below.
Check my freebies on a regular base, click the banner below.
smalll ( ) posted Sat, 07 June 2008 at 7:48 AM
Thank you Jestertjuuh**.
You are kind enough to examine it.
It was of much service to me.**
Miss Nancy ( ) posted Sat, 07 June 2008 at 2:34 PM
그렇습니다, 0에서 1.까지 posersurface의 투명도를 살리는 것이 가능하다.
raven ( ) posted Sat, 07 June 2008 at 3:08 PM · edited Sat, 07 June 2008 at 3:16 PM
You can fade characters out in Poser if you want. It's a matter of enabling animated materials in the material room. You do this by clicking the little key on the PoserSurface tab next to Transparency and Transparency_Edge. Move the animation frame slider to the frame number you want the object to completely disappear and set the Transparency and Transparency_Edge values to 1. You will have to do this for every part (and material zone) of the object you want to disappear, which can be very time consuming. Poser will then animate the object fading out. Here is an example I did to show you. A 24 frame animation that had Dr Who's TARDIS disappearing. Frame one the transparency settings are at 0, and at frame 20 I set the values to 1. Poser animated the TARDIS getting more and more transparent until it disappeared. Hope that helps.
smalll ( ) posted Sat, 07 June 2008 at 4:39 PM
Wow!
The news knocks me for a loop.
It is an experience met for the first time in one´s life.
Thank you Miss Nancy and raven !
pakled ( ) posted Sun, 08 June 2008 at 12:22 PM
Attached Link: The Gimp - free image manipulation program
there's always (cue in Darkside music) postwork...;)
