Wed, Nov 20, 4:47 AM CST
Vue F.A.Q (Last Updated: 2024 Oct 26 8:50 am)
Subject: align cyclic
gateman45 ( ) posted Wed, 11 June 2008 at 9:47 PM · edited Wed, 20 November 2024 at 4:46 AM
is there a way to do this in vue?
LMcLean ( ) posted Thu, 12 June 2008 at 3:32 PM
Need more information than that. Can you explain? Thanks
gateman45 ( ) posted Thu, 12 June 2008 at 6:35 PM
would like to see the settings in replicate box to have six or 8 or any # of spheres in a complete circle around the original sphere at the same distances, on the same axis...hence, align cyclic. once i can see it i can take it from there...
thanks Bob
garyandcatherine ( ) posted Fri, 13 June 2008 at 8:57 PM
***"is there a way to do this in VUE?" *** boy did that give me a good laugh.
gateman45 ( ) posted Fri, 13 June 2008 at 9:03 PM
glad to give you a grin...so how do you do it???
impish ( ) posted Sat, 14 June 2008 at 4:18 AM
Well 4 ways spring to mind since AFAIK there is no built in feature to do this:
  1. Create your geometries in a modelling package that has this kind of functionality
  2. Manually position the objects
  3. Create the first object, move the centre of rotation and then use replicate with a rotation to place the others
  4. Write a python script
If you explain why you need to do this someone might be able to give you a better, more detailed suggestion.  For example if you are looking at creating 3d fractals with objects placed around objects you might be best off using xFrog or something similar or writing your own python script.  If you just need to do it once around one object then using replicate with a little simple maths is probably best...
Peggy_Walters ( ) posted Sat, 14 June 2008 at 10:40 AM
It's called a Polar Array in AutoCAD.  It would be a nice feature in Vue, but using method 3 from impish should do the trick.  I always forget to move the pivot point...
LVS - Where Learning is Fun!
gateman45 ( ) posted Sat, 14 June 2008 at 11:19 AM
yes #3 makes sense, i always think of rotation as "object rotation"
need to think globally....thanks
