Sat, Nov 9, 8:18 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 08 10:28 pm)
Subject: V4 to V3 ??
EL-Aiko ( ) posted Sat, 14 June 2008 at 3:49 AM · edited Sat, 10 August 2024 at 2:18 AM
What can I do with V4 to V3?
Have seen it on a friedns PC. But the V3 Texure also the V3 Morphs works not with V4toV3.
So for what she is ??
Thanks for all anwerts.
lna
Acadia ( ) posted Sat, 14 June 2008 at 4:19 AM · edited Sat, 14 June 2008 at 4:20 AM
Are you referring to this product?
http://www.renderosity.com/mod/bcs/index.php?ViewProduct=59018&vendor=240894
Here are 2 threads with information on how to use the remapped V4 figure.
http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3174795
http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3072301
V4 is a completely different figure than V3 so each needs their own morphs and textures.  While David's remapped V4 will allow you to use V3 textures on her, you will still won't be able to use V3 morphs on V4.
EL-Aiko ( ) posted Sat, 14 June 2008 at 4:41 AM
Hi
Thanks for this infos.
Quote - Are you referring to this product?
modus0 ( ) posted Sat, 14 June 2008 at 11:53 AM
If you're talking about the V4toV3 figure, then it's the same as the V3 to V2 figure, which it rigged to wear the older figure's clothing.
So the V4 to V3 figure can wear V3 clothing, and should bend like V3, but takes V4 textures. And unfortunately the V4 morphs don't work either, IIRC.
________________________________________________________________
If you're joking that's just cruel, but if you're being sarcastic, that's even worse.
Acadia ( ) posted Sat, 14 June 2008 at 1:50 PM
Quote - If you're talking about the V4toV3 figure, then it's the same as the V3 to V2 figure, which it rigged to wear the older figure's clothing.
Actually, David's remapped V4 to V3 figure is still V4 so it needs V4 morphs and it can still only wear V4 clothing unless you use a clothing converter program.  The only thing the remapping did is to allow you to use V3 skin textures on V4.
There is currently no program or utility that will allow you to go in reverse....using V4 skin textures on V3. Daz has one in the making but when it will be released is anyone's guess.
modus0 ( ) posted Sat, 14 June 2008 at 3:56 PM
That however, is an entirely different figure than the one installed along with Victoria 4, which is simply V4 with no morphs and the V3 rigging.
EL-Aiko ( ) posted Tue, 17 June 2008 at 7:12 AM
Thanks to all for your infos.
