Wed, Nov 20, 12:32 PM CST
Bryce F.A.Q (Last Updated: 2024 Nov 12 7:03 am)
Subject: Help Exporting from Max to Bryce6
VbSparky ( ) posted Fri, 27 June 2008 at 3:38 AM · edited Sun, 03 November 2024 at 3:50 AM
To start off with im totally new to 3d studio max.
I created my model in 3d studio max ,  lets say my model has 3 parts to it.
I name each part in the object properties.
Then i open the material editor.
Select the first spot.
Click on the Ambient and set the color to red.
Click put to library and use the objects name.
Then i click Assign material to selection.
Shader basic parameters = Blinn
When i export this as a wavefront obj i set to group by material, check use materials
and check create material library.
when i import this into bryce6 , the object is black.
i click on the object select one of its parts, goto the material editor,
the diffusion is set to blue (not red) and the diffused value is .3 and ambient is 0.
can someone tell me whats going on here with the mtl file ..
judyk ( ) posted Fri, 27 June 2008 at 4:33 AM
You could try exporting it as a 3DS -  that works fine for me from Max 6, and all the textures are transferred to Bryce OK (but still need a bit of tweaking).  Can't help you as regards obj, I'm afraid as Max 6 doesn't support that export format. Try the guys in the Max forum.
dan whiteside ( ) posted Fri, 27 June 2008 at 7:05 AM
 This is a bug in 6.1.
One thing you can do is to use the Bryce/DAZ Studio bridge - Load Bryce and hit the big "S" gadget from the create palette and then from the D|S use the Import item from the File menu using the Import options shown. Then Quit D|S and (at least for me) this loads correctly into Bryce.
Most people just download the free Bryce 5.5 from Download.com and use that for .OBJ imports and load the 5.5 saved file into B6.1.
bobbystahr ( ) posted Fri, 27 June 2008 at 8:19 AM
good workaround Dan.. ...
I see a sound
and try to write it down
Tinkling light sound
The Sun comes up again
TheBryster ( ) posted Fri, 27 June 2008 at 8:42 AM
Forum Moderator
Heresy!
VbSparky ( ) posted Fri, 27 June 2008 at 9:12 AM
Thanks dan , never even thought of trying the DS bridge..
FranOnTheEdge ( ) posted Tue, 29 July 2008 at 11:07 AM
Yeah on the B5.5 route, but there is a bug report on this in with Daz, and there's recently been some activity in that bug report so there might one day even be a fix for this in B6...
Holds breath - then thinks better of it
ROFL!
Measure your mind's height
by the shade it casts.
Robert Browning (Paracelsus)
Fran's Freestuff
http://www.FranOnTheEdge.com
bobbystahr ( ) posted Tue, 29 July 2008 at 11:14 AM
You blue yet Fran...LOL....exhale now please.. ...
I see a sound
