hipps13, be more specific.
I don't have a lot of problems with crash in the bryce, but lately it is frequent.
But in my case, I think know.
1 year ago I am creating 75 objects (OBP) exclusively for Bryce where I will set up Brycetopia, a city totally done in Bryce using primitive forms.
It happens that after creating the objects I record like OBP and later when I try to import Bryce he/she doesn't answer and the times he/she gives mistake of it file not fond.
The times that Bryce didn't answer, it was when I opened some very big file, above 30 MB and with a lot of textures 2D.
I increased the RAM memory for 2 MB and the problem decreased but it didn't stop.
Hugs.
In response to your IM:
If your drive space is low, (I've seen computers with 10-15% free space left) your system has no virtual "swap" space to operate and a large file being written will lock or re-boot the system at the same percentage each time. Also dhama hasd a good point too, if you have a large or extreme texture placed in a certain area, the render will be fine till it reaches that point.
I push my system pretty hard with enviromental extremes, ie: lighting and atmosphere, which requires me to create mutliple Bryce scenes to composite later in a 2D editor.
Experiment with models that have only gray mats, then load the mat after the scene has rendered, and Plop render that area.
Some times you'll have to use Work-arounds like this for heavily textured and complex scenes.
I'm sure others have their own methods too.
I'm short on time this morn.....be back later
___
Ockham's razor- It's that simple
I can create images
but cannot render
Bryce stops and will not respond
any suggestions would be so appreciated
