Sun, Feb 2, 5:14 PM CST
Subject: texturing obj files with pictures....
FCLittle ( ) posted Wed, 02 July 2008 at 7:33 PM · edited Sun, 02 February 2025 at 4:46 PM
How do I do this?  Sometimes it seems to work, and other times it doesn't.  I'm so fed up with this right now I can hardly think straight to properly describe this problem.  I'm sure someones' had this problem before and found the answer so please help!
Also, it has to be for obj files because the program I'm modeling with (Silo) keeps malfunctioning when I try to export as 3ds (which, of course, work fine with pictures)...
thanks!
Mazak ( ) posted Thu, 03 July 2008 at 1:32 AM
Not all objects have UV mapping coordinates. You can use on this type of objects Standard, Spherical or Cylindrical mapping method (try what best fit). If you have problems with applying textures use the Basic Material editor! Later you can always switch back to Advanced Material Editor.
Mazak
Google+ Bodo Nittel
Monsoon ( ) posted Thu, 03 July 2008 at 8:54 AM
I have found that it really helps sometimes to put your obj through UVMapper and give it a new UV before bringing it into Vue even though Silo may have given it one...
chippwalters ( ) posted Sun, 06 July 2008 at 1:46 AM
Attached Link: http://www.altuit.com/webs/altuit2/VueStepbyStep/MappingNotes.htm
Check out the attached link-- and there are a few other tutes there as well.
