Mon, Nov 25, 11:59 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: Close Up Vertex Selections
Sueposer ( ) posted Fri, 04 July 2008 at 12:04 PM · edited Fri, 22 November 2024 at 7:57 AM
When I select vertices in the vertex modeler, the loop tool must start OFF the mesh in order to make selections. When I am working close up on a mesh, off-the-mesh is not an option for starting the tool and I am reduced to clicking on each polygon to make selections. click. click. click. yawn. wrong click. Aaaagh!
Is there another way to select that I have missed? How do others handle close-up many-polygon selection? This is all for setting up morph zones on a big figure, btw.
Thanks for any suggestions.
geep ( ) posted Fri, 04 July 2008 at 2:02 PM
Hi Sueposer,
You might try using wire display mode and then ...
You can click & drag across a number of polys in one step to select 'em.
Got a wrong vertex or poly?
Hold down the shift key and click on it. (or click & drag) to do more than one at a time.
What's that?  You need to move (or scale) some polys that have other polys behind 'em?
Rotate the camera as necessary and then ...
Click and drag around the polys you want to hide ...
(so you can't see 'em or select 'em accidentally).
Then use the [menu] "View" >>> "Hide Selection" (Ctril+)
Now that they're out of the way, you can modify the ones you want to change.
Ok? ... OK! ... 😄
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Sueposer ( ) posted Fri, 04 July 2008 at 6:48 PM
Thanks. It never crossed my mind to change the viewing mode or hide anything. I will give it a try.
