Sun, Feb 16, 8:19 AM CST
Subject: Oops.....
ssgbryan ( ) posted Sat, 05 July 2008 at 12:23 AM · edited Wed, 05 February 2025 at 6:53 PM
While doing some work in poser, I have managed hose it up just a bit.
I have extended down the menu palette that holds the Categories & Collections tabs below the edge of the display.  I can no longer reach the right-hand corner to adjust the size of the palette.
Does anyone know how to fix this short of a complete reinstall?
Running OS X 10.5.4 on a 1gen Macbookpro.
Paloth ( ) posted Sat, 05 July 2008 at 12:42 AM
Does your system have a toolbar at the bottom of the screen? If so, pull it down and out of sight. Once that's done you should be able to get a hold of the Poser tab. If that proves impossible, set General Preferences to "Launch to factory state." It’s found in the edit menu.
ssgbryan ( ) posted Sat, 05 July 2008 at 1:17 AM
I did both before I posted.
While reading your post Paloth, it occured to me that my second monitor may be causing the problem.  I disconnected the external monitor.  That forced the system to reorient back to a 15" screen.
Problem solved.
Thanks.
