Tue, Dec 24, 7:30 AM CST
Subject: Deleting frames from the beginning of an animation...?
DarkEdge ( ) posted Fri, 04 July 2008 at 10:14 PM · edited Tue, 24 December 2024 at 7:26 AM
I know that I can delete frames from the end of an animation but how would I delete frames from the beginning of an animation?
Or can you start an animation from frame 30 let's say?
EdW ( ) posted Fri, 04 July 2008 at 11:07 PM
To delete frames at the beginning you need to delete the keyframes from frame 1 to the frame before the keyframe you want to use as the new frame 1. You can not delete frame 1. You have to manually move the remaining frames (select all of the remaining frames and drag them until your new start frame is at frame 1).
What you will end up with is empty frames on the end of your animation.
Hope this helps you a little:)
shuy ( ) posted Sat, 05 July 2008 at 5:42 AM
DarkEdge ( ) posted Sat, 05 July 2008 at 8:05 AM
Great, many thanks! 😄
