Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2735605
You should also consider supplying unhide poses so that (for whatever reason) people can unhide any hidden dials without having to edit files (see a few pages into linked thread).Quote - In the CR2 or PP2, find the rotate channels for the body part. Change the attribute from hide 0 to hide 1 for each one you want to hide. Save the file.
John
Just because they are hidden does not mean they won't rotate. You should also force limits so it does not rotate. Here is an example of what it should look like. I do recommend a a good editor like Cr2 Edit
rotateY yrot
name yrot
initValue 0
hidden 1
forceLimits 1
min 0
max 0
trackingScale 1
keys
static 0
k 0 0
Poserverse The New Home
for NYGUY's Freebies
Yes. 1 is a user setting "which can be overridden by Poser" whereas 4 is a setting inwhich Poser respects the setting and does not override it. Things like IK though DO NOT RESPECT these settings. Caveat Emptor...
C makes it easy to shoot yourself in the
foot. C++ makes it harder, but when you do, you blow your whole leg
off.
-- Bjarne
Stroustrup
Sorry but that's not correct. 'forceLimits 4' and 'forceLimits 1' both do exactly the same thing. P4 used 'forceLimits 4', but they changed the parsing (I think in P5) to 'forceLimits 1'. All current versions including P4 will accept either variant. The poser interface provides no way to change the 'forceLimits' flag (a py script may be able to do it).
The "Use Limits" switch in the Figure menu is something complately diffrent, and has no effect on the 'forceLimits' flag (but will override 'forceLimits 0'). The "Use Limits" switch is a global setting, it applies to the whole document. The flag itself lives in the 'doc' section of the pz3, it is named 'useLimits', and accepts a value of 1 for on, and 0 for off. When 'useLimits' is set on all channels in the scene will use limits, even those that have 'forceLimits' set to zero. When 'useLimits' is set off, a channel will use limits according to the status of its 'forceLimits' flag.
A long time ago someone (I know who, but I'm not sayign) said that 'forceLimits 4' and 'forceLimits 1' had different effects, and every one just accepted that without bothering to check if it was correct. It's the number one Poser superstition!
Nothing you can do from the Poser interface will un-force xrot or yrot.
Okay, so I fell for 'someone's' saying on this. ;)
But does "Use Limits" also apply to IK? As far as I can tell, IK ignores limits whether set in the channel or with "Use Limits" enabled. The figure has valid Min/Max limits set.
off.
-- Bjarne
Stroustrup
@ kuroyume,
Quote - But does "Use Limits" also apply to IK?
I didn't know the answer to that one, but it's an interesting question, so I took a look. In P6 It seems like forceLimits will not be respected when IK is on. Strangely enough "Use Limits" (useLimits) is respected for all actors except the goal actor. I would have expected forceLimits and useLimits to be the same in this respect. Just goes to show, Poser is still full of surprises, even after all these years!
If you want to see something really weird take a close look at Jessi's eyes!
How do you make one or two of the x-y-z-Rotate dials in Poser invisible.
I have noticed some third party figures have this and would like to know how to do it
Thanks
Pappy
