heyas; the fake neck doesn't need any actual geometry, only the neck joint parameters. it sounds as if you set up your conformer by hand, instead of cheating and creating a conformer cr2 from the base figure (or previously existing clothing). the quickest thing to try would be to add an empty neck body part into the top part of your cr2, then just insert the neck entries from the standard michael cr2. you'll have to make sure the initvalues for that are set to zero. AND remember, that besides just pasting in the neck entry in the second section of the cr2, you have to add info into the chest section, for the neck; and in the figure section for all the add child bit and whatnot. there's a tutorial on inserting extra body parts on my goodies page, that should help point out what to look for. the other thing you might try.... if you give the chest a very slight twist, and it fixes the 'listing to port' problem.... you can set your conformer cr2 to have an initvalue for the twist to be like .001. i've found that cures a lot of conformers that get twisted up.
