Fri, Feb 7, 6:04 AM CST
Renderosity Forums / Blender
Welcome to the Blender Forum
Blender F.A.Q (Last Updated: 2025 Feb 02 8:19 pm)
Welcome to the Blender Forum!
   Your place to learn about Blender, ask questions,
   exchange ideas, and interact with the other Blender users!
   Gallery | Freestuff | Tutorials
Visit the Renderosity MarketPlace. Your source for digital art content!
Subject: How to export hair ?
sirenia ( ) posted Sat, 12 July 2008 at 1:22 PM · edited Fri, 31 January 2025 at 2:02 AM
Hi,
I made a simple plane and gave it hair particles on the top, so that it looks like a floor mat / rug.
When i export this as an OBJ or a 3DS, the only thing that is exporting is the plane, but no hair whatsoever...
Must i 'bake' the hairs first or something like that ?
Thanks
Wim
Society failed to tolerate me...
... and i have failed to tolerate society
nruddock ( ) posted Sat, 12 July 2008 at 2:52 PM
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2735607
The particle tracks go in to OBJ files as lines, which may show up in some programs, but usually don't render.
The linked thread may help a little.
RobynsVeil ( ) posted Sat, 12 July 2008 at 6:28 PM
Quote - Hi,
Thanks
Wim
I ran into that exact problem... and when I imported into Poser - I was trying for grass at the time - I couldn't even see the character's legs or feet when the grass object was selected in the viewport because of the red lines... indicating the 'grass' did import, but Poser didn't know what to do with it, and wouldn't render it. I think it might have something to do with the thickness of the mesh - need to make the particle strands thicker somehow, but how? Maybe that above link might have a clue...
Metaphor of Chooks
lisarichie ( ) posted Sat, 12 July 2008 at 11:06 PM · edited Sat, 12 July 2008 at 11:07 PM
The quick and easy solution is to simply select all the strands and extrude by a minute amount to create faces yet maintain the appearance of strands.
Attached a quick example of particle generated mesh rendered in D|S.
sirenia ( ) posted Sun, 13 July 2008 at 1:21 PM
lisarichie,
Can you explain how to extrude the hairs in Blender ?
And how can i make the hairs editable in Blender ?
Thanks
lisarichie ( ) posted Sun, 13 July 2008 at 11:16 PM
Create the particle strands and apply all the modifications required.
Press F9 to enter editing
Under the modifier tab click Convert
Press TAB>A to select all the vertices
Press E>ONLY EDGES>X>.001 to extrude a minute amount along the X-Axis. You can of course do this according to whichever axis is most suitable for your situation.
This creates simple strips of faces that are renderable in outside programs after exporting the hair mesh.
Of further note, you can extrude the faces created  by the same amount along the perpendicular planar axis to create square strands then apply the subsurf modifier to round and taper the strands.
This creates much more realistic hair but is only effective for sparse hair such as eyelashes, eyebrows and random body hairs because of the huge increase in poly count.
Example: 1000 particle strands of 5 vertices each after extrusion equals 10,000 vertices. Extruding again raises the count to 20,000 vertices. Applying the subsurf modifier at the default setting will then generate approximately 80,000 vertices.
A good compromise is to create the bulk of the hair using traditional methods and generate a few strands of particle generated mesh strands for realism using the double extrusion outlined above.
RobynsVeil ( ) posted Mon, 14 July 2008 at 3:25 PM
Thanks, Lisa... very well explained. I'll have a go with my grass, import to Poser and do a render... plus you gave me some more keystroke shortcuts... this is so COOL!
Metaphor of Chooks
sirenia ( ) posted Sat, 19 July 2008 at 5:22 AM
Thanks for explaining Lisa :-)
l3la ( ) posted Fri, 25 July 2008 at 10:42 PM
Thanks. Great tip that I will use for sure.
