Wed, Nov 20, 6:34 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: Dialog boxes
Anthony Appleyard ( ) posted Fri, 18 July 2008 at 12:41 AM · edited Wed, 20 November 2024 at 6:30 AM
In a Python script I want to use the function DialogFileChooser, but the manual says that it was introduced in Poser 7. I have Poser 7; but what % of Poser users still use Poser 4/5/6?
markschum ( ) posted Fri, 18 July 2008 at 1:18 AM
Hence tkinter :)
There are a lot of people with versions earlier than 7 . Its a choice to decide what you will support with scripts . V4 is really only supposed to work with Poser 6 or 7 .
Depending on what you are doing you might document the manual procedure for earlier versions or use tkinter .
semidieu ( ) posted Fri, 18 July 2008 at 2:16 AM
But don't forget that Tkinter is not available in Poser 5/6 on Mac !!!
Anthony Appleyard ( ) posted Fri, 18 July 2008 at 6:29 AM
Please what is Tkinter and where to download or buy it?
PhilC ( ) posted Fri, 18 July 2008 at 6:55 AM
Tkinter is a GUI module for Python.
It is already installed within Poser.
See:-
http://www.pythonware.com/library/tkinter/introduction/
http://docs.python.org/lib/module-Tkinter.html
markschum ( ) posted Fri, 18 July 2008 at 4:17 PM
Philc has a Python manual/tutorial product that gives working examples of stuff and explains tkinter.  I find tkinter a bit of  a pit  myself so I tend to edit scripts to get parameters and file paths into scripts .
or check out some of these.. http://wiki.python.org/moin/TkInter
semidieu ( ) posted Fri, 18 July 2008 at 4:31 PM
Also, another important note:
Poser 4 users do not have python
Poser 5 users has python, but a LOT is limited...
Poser 6 users... HAS the DialogFileChooser, at least in the latest update.
I just tried this code:
import poser
dlg =
poser.DialogFileChooser(poser.kDialogFileChooserOpen, None,'')<br></br>
if dlg.Show():<br></br>
 print dlg.Path()
bagginsbill ( ) posted Mon, 21 July 2008 at 7:45 AM
As Semidieu says, I've found also that these functions were introduced in a Poser 6 SR, so most people have them.
jenay ( ) posted Tue, 22 July 2008 at 6:10 AM
here is a small test snippet that could do the job:
from Tkinter import *
import tkFileDialog
fn=tkFileDialog.asksaveasfilename()
pz2Out=open(fn,'w')
pz2Out.write("... und aus is ...")
pz2Out.close()
