Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 23 9:03 pm)
wait, the fresnel shouldn't affect your render time at all. reflection might, but the fresnel as bagginsbill suggests just uses an edge blend node to control your reflection and refraction, and possibly your specular (i forget right now). i'd think in testing at least, you could keep your reflection and refraction quality/samples low.
Yeah, when I plug in the edge blend node, the render times seem unaffected.
I was experimenting with fresnel node itself. That one kills things.
Edge blend node does give a nice voluminous effect :)
I'll post what's rendering in a little bit, when it's done.
Hi, my namez: "NO, Bad Kitteh, NO!" Whaz
yurs?
BadKittehCo
Store BadKittehCo Freebies
and product support
yurs?
BadKittehCo
and product support
It went from 15-20 minutes with one shader, to almost two hours after tweaking a shader.
I added reflection node and a fine bump.
Soo... back to the drawing board...
yurs?
BadKittehCo
and product support
zooo... I dared to download and install P7, Sr3 which just came out, and it appears to have fixed the gridding issue on shaders.
It introduced some silly artifact on my skydome though. LOL, so it goes!
yurs?
BadKittehCo
and product support
Yeah, they're static unrigged ungrouped OBJ's for people whom may want to do some texturing :)
Nothing else to test at the moment, till we get closer to finished with rigging.
yurs?
BadKittehCo
and product support
yurs?
BadKittehCo
and product support
Yea, ok, I had to get shiny liquidy latex out of my system.
yurs?
BadKittehCo
and product support
Hi people. Cool stuff here. I happened to see my name regarding Fresnel, so I popped in.
Don't use the Fresnel node for this - it does refraction as well as reflection, resulting in a cool effect for water or clear glass, but not what you want for shiny clothing.
Reflections alone will cause an increase in render time, but pretty mild. Refractions are terribly slow, but necessary for certain materials.
My thread on Fresnel reflections from way back is actually just an approximation of the Fresnel effect, and a rather poor one at that. Even the Fresnel node is not accurate. I recently constructed, from first principles (by using the actual Fresnel equations) a shader tree that accurately performs Fresnel reflection. I used it in my free Orb shaders.
http://market.renderosity.com/mod/forumpro/showthread.php?thread_id=2743322
http://sites.google.com/site/bagginsbill/free-stuff/orbs
The first shader in that set, Orb001_Opaque would actually make a pretty good shader for any glossy material such as latex. Just change the color in the Simple_Color node at the top of the shader. Or, set it to white and attach a color map.
Of course you don't have to use real reflection. You could use a reflection map with the sphere_map node instead. You'd still want the Fresnel effect with that, though. Go into the shader and find the Reflect node. Replace it with a Sphere_Map + Image_Map combination.
The amount of shininess is based on the Index of Refraction (IOR) of the material. I know, that sounds strange for materials that don't refract, but it still applies. I used an IOR of 1.54 for glass. There are four math nodes in the shader that have this value in them. You can change the IOR to any value you want. The IOR of metals is really high, like over 50. If you put 50 in there, you will get a really shiny material, with nearly uniform reflection across any angle. Values closer to 1 will produce less reflection, but still appear to have very strong reflection at the edges. It's all in the Fresnel equations - you only need to adjust that IOR for any realistic effect. The Edge_Blend trick I used to do just doesn't cut it any more.
Also - that shader implements Gamma correction, so the reflections blend correctly no matter what color the material is. Try white and black. Compare the results to other, more naive, reflection shaders that don't use gamma correction - resulting in non-linear math in your shader. You'll be surprised at the difference in realism.
If anybody wants to know more about accurate Fresnel, speak up.
Quote - Hahaha! Hey Connie, feel like adding in the new "Elite morphs? :scared: :lol:
I can always make them as an injectable add on ;)
You know, to keep the initial OBJ load smaller, some of the morph groups in the outfit are going to be injectable anyway. :)
yurs?
BadKittehCo
and product support
Oooh, Bagginsbill, thank you so much for popping in :)
I'm going to run out to get my morning cofee, and sit down and carefully read through the advice you're offering.
For those of you whom may not know Bagginsbill, he's like the Demi-God of procedural shaders!!!! I feel blessed by having him stop by and offer input!
faint
[open one eye... I better go get my coffeee...]
yurs?
BadKittehCo
and product support
:blink: :blink: :blink:
Where'd everyone go?
I know, there's a party and I didn't get invited! :crying:
yurs?
BadKittehCo
and product support
yurs?
BadKittehCo
and product support
If you look at the reflection really hard, you see that face from your sig popping in and out of view ;) Spoookey!
Hey stormy, I haven't seen you in beta forums in a little while, you may be interested in poppin in over there :)
yurs?
BadKittehCo
and product support
yurs?
BadKittehCo
and product support
It's the reflections, huh?
You're blinded by them :tt2:
yurs?
BadKittehCo
and product support
Indeed the reflections are perfect! I can see you licking your tail in them, trapped you are! ^^
Just popping by to say i WANT THIS! also ive read thru the thread and its very interesting to se how and what is involved in making this.
Dont know much abouyt modelling but im hoping to some day get the patience and motivation to learn enough to make some stuff of my own, things like this really helps in increasing motivation, even if its years out of my reach :)
Ooh, Thank you Izy and Zhack, so nice of you to pop in :)
Zhack, I can't believe you actually read through the thread - What patience!!! If you can make it through the thread here, you can definately get good with modeling.
I'm glad to hear there are people whom find the thread motivating and informative too. Usually I worry that people will get mad at me about it being self serving.
Making theese threads helps me stay motivated. LOL once I announce to the whole world I'm making something, I can't quit when it gets too hard.
Work update - I managed to get couple of the custom JCM's work - in the experimental attempt. Now I have to load them all, see where they need touching up, then do them again 'for real'.
I think after that the suit wil be rigged and ready for beta testers to take it apart.
I think if I do that first, the rigging of vest, holster and boots will go much smoother.
yurs?
BadKittehCo
and product support
WooHoo!!!!!! now your getting me excited, and right before I gotta go to work and be brought down by real life! :lol:
Looking forward to the official beta version!
LOL, of course, today I can't seem to concentrate on it, so I'm meandering around all kinds of distractions.
I think I'm afraid of getting so tangled up in the JCM's and ERC, that it'll take me a month to get untangled. nervous laugh
yurs?
BadKittehCo
and product support
I may have to post a pre-JCM render of the same thing so people can see the before and after.
yurs?
BadKittehCo
and product support
yurs?
BadKittehCo
and product support
Quote - Thats okay Connie, with an outfit like this, I would turn the legs and what not off anyways! :D maybe I am the only one that does that?
Turning off body parts is actually more of a norm. It still may need doing, especially with other body morphs and shapes.
I'm just patting myself on the back for making the JCM's work :)
yurs?
BadKittehCo
and product support
beta beta beta beta ..... here beta beta betta betta
http://forum.okcrandy.com/viewtopic.php?f=2&t=362&start=90
Here beta beta ;)
yurs?
BadKittehCo
and product support
Thank You Shadownet :)
I dunno about it posing oh so well just yet... but maybe it'll get there.
yurs?
BadKittehCo
and product support
LOL Well it looked "posed" oh so nice in the pics I looked at. :O)
Poser being Poser, its never perfect. But I applaud you for making the effort. I am also impressed with what you were doing in Hexagon. I started with Wings3d after trying a few other free modeling programs, and finally learned it. I bought Hex to learn but never could seem to make heads or tails out of it. Seems like whatever tutorial I tried the layout was different or things did not seem to want to work the same for me as described. Half the time, I could not even find some of the buttons they were saying go look for, because my version was different (newer) than the one used in the tutorial. And being time limited, I just went back into Wings and modeled what I needed there. Still, I am hoping to one day sit down and learn Hex.
Ugh, I managed to fresnel myself into a corner of loooong render times. Very looooooong render times. Back to the drawing board!
Hi, my namez: "NO, Bad Kitteh, NO!" Whaz yurs?
BadKittehCo Store BadKittehCo Freebies and product support
