Wed, Feb 19, 3:57 PM CST
Forum Moderators: RedPhantom
Subject: how do you get a boot to conform?
originalmoron ( ) posted Tue, 22 July 2008 at 8:44 AM · edited Fri, 14 February 2025 at 2:14 AM
Hello. I have looked and searched, but I cant find any tuts that show how you get a selfmade boot to conform. At least not all the steps. I have found some scattered details, but I dont get it to work as it should. Do any of the Poser gurus here know of any Poser6 tuts I may have overlooked?
My blog
manoloz ( ) posted Tue, 22 July 2008 at 9:10 AM · edited Tue, 22 July 2008 at 9:11 AM
Weld your mesh groups
http://www.nerd3d.com/modules.php?name=Content&pa=showpage&pid=11
still hooked to real life and enjoying the siesta!
Visit my blog! :D
Visit my portfolio! :D
JoePublic ( ) posted Tue, 22 July 2008 at 9:15 AM
  1. ZERO figure (NO morphs, NO posing, NO scaling) the boot should be conformed to.
  2. Create boots to fit the ZEROED figure.
  3. Group boots so that their bodyparts NAMES and general layout match EXACTLY those of the figure's legs. (lShin,rShin,lFoot,rFoot,lToe,rToe)
  4. Import the grouped object into Poser. (Does the boot still fit the ZEROED figure ?)
  5. Enter the SetUp room.
  6. Select a cr2 from an already rigged pair of boots that were made to fit to your figure.
    (Joint settings are NOT copyrightable, so you can freely use any existing cr2's you have to "borrow" the joints.)
  7. Enter Pose room.
  8. If nothing went wrong, your boots are now conforming clothes.
grichter ( ) posted Tue, 22 July 2008 at 3:49 PM
 Or get phil c's Obj2cr2. Quick and easy. Load the target figure, import the object, load a prop and convert and it is done in seconds. I know it works on clothes. Nit sure if it works on shoes and boots. And as of this morning I personally know it works with P7 SR3 and PoserPro which a dev version of V4.2 with no magnets.
Granted Joe Publics method is very easy also. The advantage of Obj2CR2 is you can adjust the postioning via scripts if you are not happy, vs going back into your modeling program to move your item realitive to the body you are trying to conform too
Gary
Conniekat8 ( ) posted Tue, 22 July 2008 at 7:06 PM · edited Tue, 22 July 2008 at 7:06 PM
Nice looking boot!!!
Make sure Weld body parts in Poser's Parameters panel is turned ON.
Also make sure your boot is properly grouped.
Letterworks ( ) posted Tue, 22 July 2008 at 11:06 PM
Honestly, for a boot like that I would only HAVE one group... left or right Foot.  Since there is only a single group BEFORE the foot and one aftrer it (l/rShin_l/rFoot_l/rToe) the pre (parent to) and post (child of) groups to the l/rFoot will operated even if the boots don;t have a physical group. Of course you must have the Shin and Foot groups in the CR2 file.
If you are using Posers Setup room the load your boots with the single group into poser go into the setup room and inject the donor skeleton as normal. If you are using a full skeleton as in one of the Development figures you can manually delete many of the groups as superficial onece you save off the boot(s) as a figure.
I recomment using a CR2 creation program, I believe PhilC's was mentioned above. I use one in Dimension3D's Poser Tools (sold in the marketplace here). I'm not sure about Phil's but with the one from D3D you select your object file, select your Donor Cr2 file and the location and name of the new clothing file. The program then writes a new Cr2 elelminating a lot of the unnecessary groups leaving just the Group before and the group after the last physical group in the Object file. Perfect for this. I assume Phil's probably does the same. Saves a lot of hand editing.
You may also have to tweak the Spherical Falloff groups in the Joint editor if the boots are much larger than the feet..  If you notice some small vertex "pulls" when bending the joints simply enlarge the falloff groups slightly (really small changes) until the puls disappear.
originalmoron ( ) posted Tue, 22 July 2008 at 11:55 PM
Hmm, many good advice here. I have to try some of them. I'll get back to you :)
My blog
originalmoron ( ) posted Fri, 25 July 2008 at 1:49 PM
Well, I give up. I redesigned the boots cos I didnt like the first shape, so I'm quite pleased with that at least. But I cant get it to work right. Do anyone know some Godess/God who could make the boots conforming to Jessie for me? Its a pair of boots in it for her/him if you like them. The textures you see as well. They are 3000x3000. Here are a render in Carrara and Poser of the boots.
My blog
bopperthijs ( ) posted Fri, 25 July 2008 at 3:51 PM
Philc's obj2cr2 doesn't work so well on shoe's or boots. You can try his shoedesigner, or use quickconform and groupeditor to make the cr2
Bopper.
Realmling ( ) posted Sat, 26 July 2008 at 9:27 AM
Originalmoron - Are these for Jessie G1 or G2? (unless there's no rig difference between the two..don't use her enough to remember)
I'd be happy to help get them conformed for you. I have both Jessies (just have to find the backup disk with G2 on it) so it wouldn't take much to get these done. I'd just need the Poser scaled obj file to get going on it.
Crazy alien chick FTW! (yeah....right....)
Realm of Savage - Poser goodies and so much more!
originalmoron ( ) posted Sat, 26 July 2008 at 9:58 AM
Hmm, G1 or G2. Were do this stand? Poser is not something I use alot. I'm more of a modeling and Carrara guy :)
My blog
Realmling ( ) posted Sat, 26 July 2008 at 5:10 PM
There's Jessie G1 that came with Poser6...and then they released a separate 2nd gen jessie figure. I just can't ever remember if they changed the rig any between the two versions. Course, I could do for both too. Doesn't take too long.
Letterworks ( ) posted Sat, 26 July 2008 at 5:24 PM
Jessi 1 came with Poser 6, Jessi G2 is a seperate figure and "shares" the same body shape and rig with Poser 7's Sydney female figure.
So if your boots are build around the P6 Jessi they probably won;t fit the G2 Jessi figure (or the P7 Sydney figure) and vice versa.
originalmoron ( ) posted Sun, 27 July 2008 at 12:37 AM
Ok, Its Jessie G1 then. I'll send you a sitemail with the downloadlink when I have gotten it uploaded Realmling.
My blog
EnglishBob ( ) posted Mon, 28 July 2008 at 4:13 AM
Attached Link: http://www.morphography.uk.vu/dlnancy3.html
Sorry to hear you've given up - but it  looks as though you have the help you need. For the benefit of anyone else reading, I just wanted to agree with Letterworks' advice above:
Quote - Honestly, for a boot like that I would only HAVE one group... left or right Foot.
That approach works very well. One big advantage is that if you build one boot and mirror it (which is the sensible thing to do!) you only need to make morphs for one boot as well - then you can mirror the morphs too. It worked for me - here's a pair I made for V3.
originalmoron ( ) posted Mon, 28 July 2008 at 4:41 AM
Very nice boots indeed. I have understood that Jessie aint that much used. Looks like Victoria are the preffered choice for Poserartists? And about Victoria, are her foot supposed to tilt that much when being zeroed? Do I have to model a boot around that tilt?
My blog
obm890 ( ) posted Mon, 28 July 2008 at 6:12 AM
I think they pointed her foot like that in the default pose because they realised that 99% of footwear made for V3 had very high heels. Even combat boots, fireman's boots, deep sea diver's boots, stone-age sandals etc for V3typically have a 7" stiletto heel  ;-)  Hell, I'm sure I'd have sold more ski-boots for V3 if I'd given them a ballet-point toe :-D
I think  I would model the boot as you want it to look, then bend it (or better still, a copy of it) at the last minute to fit her zeroed foot pose.
originalmoron ( ) posted Mon, 28 July 2008 at 7:30 AM
Hehe, ok, thanks obm. I was beginning to wonder if it was something wrong with my Posersettings :)
My blog
originalmoron ( ) posted Sun, 03 August 2008 at 10:43 AM
Do anyone else have the time to conform those boots to jessie G1 for me? It stil is a pair of boots in it for the one that helps me out here.
My blog
Letterworks ( ) posted Sun, 03 August 2008 at 10:54 AM
OM, If you still need them conformed drop me a site mail and I'll give you an email to send them to, it shouldn;t take too long to make them work for you.
originalmoron ( ) posted Sun, 03 August 2008 at 11:43 AM
I sent you a mail with download location Letterworks, and thanks :)
My blog
Realmling ( ) posted Mon, 04 August 2008 at 8:23 AM
My apologies..had some stuff come up over the weekend and didn't get a chance to finish these yet. :sad:
nyguy ( ) posted Mon, 04 August 2008 at 9:25 AM
Quote - Philc's obj2cr2 doesn't work so well on shoe's or boots. You can try his shoedesigner, or use quickconform and groupeditor to make the cr2
Bopper.
I agree on this that obj2cr2 does not work on boots. Quick Conform is your best bet. I use Shoe Designer to make the base part of the shoes but Quick Conform to make them fit. Also another thing to try is PhilC's Wardrobe Wizard, it does shoes okay but as with Quick conform you will still have to mess with the joints.
Poserverse The New Home for NYGUY's Freebies
Letterworks ( ) posted Mon, 04 August 2008 at 11:56 AM
originalmoron,
Just to prove they work on my computer here's a quick screen cap. I'm not sure why they come out twisted on yours, sadly, unless it;s because I'm using Poser 7 vs poser 6, maybe something different in the figures? Still I'll keep looking at them and if anyone else has any suggestions I'd be glad to hear them. I'm sure it has to do with the multiple joint toes in the P6 and up base figures which may be why there aren;t a lot of shoe styles for the G1 and G2 figures out there.
Anyway, I'll keep trying
originalmoron ( ) posted Mon, 04 August 2008 at 6:26 PM
Well, I surtenly dont know. Maybe I just should redesign them to fit Victoria 4 instead.
My blog
Realmling ( ) posted Mon, 04 August 2008 at 6:35 PM
Letterworks, how do you have the boots grouped around the bones? On my first attempt (I have P6), I left the shin and toe controller (deleted all the actual toe bones) and just grouped everything to the foot bone.
Things conformed fine, posed ok for the most part...except leaving the "ghost" toe controller in gave a funky bone outside the boot mesh that I couldn't get rid of, and if you posed the toes it distorted the shin area...but that's something that probably could have been corrected with the joint editor.
Can't think of anything else at the moment..
Letterworks ( ) posted Mon, 04 August 2008 at 6:44 PM
That's basically what I did, except, after looking at a pair of shoes that came in P7 for the P6 female I added a "Dummy" group to the shoe (that appears to be that funky bone you mentioned. By making it a dummy is seems to divorce the extra toe bones and you can set that odd bone to invisable.
The problem is they seem to conform fine on my system! Maybe if OM doesn;t mid I can send my files to you to try in your P6, since I don;t have it?
Realmling ( ) posted Mon, 04 August 2008 at 6:50 PM
Be happy to take a look if OM doesn't mind.
Just had another thought....one thing I remember from other projects between P6 and P7 was that sometimes you had to turn spherical zones off/on in the joint editor to fix issues in P6 if things would go funky. Now that was for figures I was helping test...but same could apply to clothing as well.
originalmoron ( ) posted Mon, 04 August 2008 at 6:54 PM
I dont mind. You should already have the boots, right?
My blog
Letterworks ( ) posted Mon, 04 August 2008 at 6:54 PM
hum, maybe because I did turn spherical on to fix the shin movement problem you mentioned.
Well we'll see what OM says and then go from there.
Realmling ( ) posted Mon, 04 August 2008 at 7:31 PM
Yup, I still have a copy of the boots...I just never managed to get a dev rig done up for Jessie this weekend to finish things up..too many things going on I wasn't expecting.
