Thu, Jan 9, 4:57 AM CST
Subject: Victoria 4.2 Muscle Morphs Inj problem
mikeymike1 ( ) posted Tue, 05 August 2008 at 6:17 PM · edited Wed, 08 January 2025 at 9:45 PM
This is really frustrating me.
I have V4.2. I have installed the base, elite and muscle morph packs. 2
I load V4.2 and look at the body parameters. BodyBuilder, Definition, Fitness, blah blah...all exist. Good.
Now I  go into the pose directory Victoria 4, Morph Injections, and double click Inj Muscles V4.
The I get this problem...
Please locate InjDeltas.FBMBodyBuilder
Whe I try to locate the file...I can't.
I'm running Windows XP
Poser 7
This is the only problem I've ever.
Can someone help me out?
Greatly appreciated!
Conniekat8 ( ) posted Tue, 05 August 2008 at 6:31 PM
Is your V4 installed in Poser's own runtime, or an external one? I gather external runtimes may have issues with this.
on my computer, the file is located here:
C:Program Filese frontierPoser 7RuntimeLibraries!DAZVictoria 4DeltasMorphs++InjDeltas.FBMBodyBuilder.pz2
Realmling ( ) posted Tue, 05 August 2008 at 6:40 PM
You can put the cr2, and pz2(inj/rem) files in a separate runtime....but because of how poser works, it looks for the deltas and all that hooha starting from the base Poser runtime. So you'll need to make sure that !DAZ folder is "happily" installed there.
So as long as all your ++ morphs and everything else are there..should work ok.
Crazy alien chick FTW! (yeah....right....)
Realm of Savage - Poser goodies and so much more!
mikeymike1 ( ) posted Tue, 05 August 2008 at 6:54 PM
My C drive is partitioned into C and E. Poser is installed on E.
I have never experienced any problems with this setup...unless Victoria 4.2 is so different that it doesn't like this.
The bigger problem, I guess, is that the InjDeltas.FBMBodyBuilder file does not exist...although it is installed, shows up in the parameters and I can manually adjust it via the dial.
Hmmmmm...any ideas.
mikeymike1 ( ) posted Tue, 05 August 2008 at 7:01 PM
Quote - Is your V4 installed in Poser's own runtime, or an external one? I gather external runtimes may have issues with this.
I followed the above route and mine looks like this.
E:Program Filese frontierPoser 7RuntimeLibraries!DAZVictoria 4Deltas
I have three folders in there:
Base, Elite and Muscle
There is no Morphs ++ folder...should there be?
I wonder where it went?
Conniekat8 ( ) posted Tue, 05 August 2008 at 7:30 PM
Are you talking about theese muscle morphs:  http://www.daz3d.com/i.x/shop/itemdetails/-/?item=5252&_m=d
It doesn't say anywhere on it that V4++ moprh package is required for it. Maybe DAZ goofed up not noticing it's needed or there's a bad call in a cr2 or something. Unfortunately, I don't have that particular set of muscle morphs, so I can't check and see what's up.
In case you didn't know already, Bodybuilder INJ is from the V4++ pack, a separate purchase, or comes bundled with V4 Pro Pack.
http://www.daz3d.com/i.x/shop/itemdetails/-/?item=4787
or   http://www.daz3d.com/i.x/shop/itemdetails/-/?item=4800&cat=350&_m=d
If you bought the ++ morphs, then those files should be there.
mikeymike1 ( ) posted Tue, 05 August 2008 at 7:57 PM
I got this pack:
http://www.daz3d.com/i.x/shop/itemdetails/-/?item=3940&_m=d
Thanks for your help.
I'll keep trying...
mikeymike1 ( ) posted Tue, 05 August 2008 at 8:10 PM
I have the Victoria 4.2 Pro Bundle but the Daz3D - ps_pe070 - V4 Morphs++ is not showing up???
Maybe I installed things in the wrong order??
I installed the V4 base (V 4.2 base)
then the V4 morphs++
then the V4 Elite Bundle
finally the V 4.2 Muscle Morphs
that would be:
ps pe069 Victoria4.2
ps pe070  V4 Morphs++
ps bn147 V4 Elite Bundle
ps mr259 Victoria 4.2 Muscle Morphs
Everything works except the muscle morphs.
This V4.2 has befuddled me...
Conniekat8 ( ) posted Tue, 05 August 2008 at 8:45 PM
I don't think the order of install would matter... but it looks like your ++ morphs are missing from the directory. I see that the package you pointed out does require them.
At this point I would try to reinstall the ++ morphs. Hopefully that solves the problem.
If not, I'm going to be befuddled too. Sowwy I can't be of more help.
mikeymike1 ( ) posted Tue, 05 August 2008 at 8:48 PM
Quote - I don't think the order of install would matter... but it looks like your ++ morphs are missing from the directory. I see that the package you pointed out does require them.
Will try a few more things...reinstall everything.
Thanks for your help. Much appreciated! : )
Realmling ( ) posted Wed, 06 August 2008 at 10:39 AM
Just had a thought -- Did you make sure to run that "update vicky" thing that should've shown up as a shortcut on your desktop after you installed everything?
I know that for some odd reason in some cases, they may not work unless you ran the updater so that the base files know that the morphs exsist.
This is by far the most convoluted system for a figure in my years using Poser....
